20 Most Recent Generic Memory PCI USB and Firewire Combo Card (sd-cb5271b-4e6i) Questions & Answers
Just plug it in and view with Windows Explorer. No drivers are needed unless you are running Win 95.
Generic Memory... | Answered on Nov 01, 2012
If neither your computer nor your camera will recognize your card then it is safe to say that there is an issue with the card. You may either have bad contacts or an internal issue, but since your camera states it is locked when you say it is unlocked that would normally signify an internal issue. If you still have a warranty on the card I would suggest you take it back to the place it was purchased from.
Generic Memory... | Answered on May 30, 2010
Open "Device Manager".
Double-click the entry for the device.
Click "reinstall driver".
Click to allow Windows to access the Internet to search for the driver.
Generic Memory... | Answered on Jan 13, 2010
i had same problem..couldn't solve it with tape over the lock switch and many other ways.. so i purchased a usb card reader (about $5 max) and now it works fine!..make sure the lock is off!
Generic Memory... | Answered on Jul 28, 2009
Try safely ejecting the card, it actually has a small switch on it, which depending on where its pushed will lock or unlock..look closely.
Generic Memory... | Answered on Jul 15, 2008
go to www.driversguide.com and do the registration and loock for your usb drivers for win 98se
Generic Memory... | Answered on Dec 28, 2007
Hello Mr. Joe, Your drivers are here: http://www.syba.com/bin/ali/m5632/m5632_drv_util_v1.20s_multi.zip Please let us know if you need any additional information. Best regards, nightdiver
Generic Memory... | Answered on Nov 10, 2006
Try Hi-Fi Corporation or where you originally bought your DVD, they can unlock it for you. I have the same and I DVD never had problems with playing imported DVDs from the US.
Generic Memory... | Answered on Mar 27, 2009
http://olevia.supportsync.com/
Generic Memory... | Answered on Feb 03, 2009
I the red led only comes on dimly, the new batteries are suspect, or they are not charged. You need to establish if its the headphones or the batteries at fault. To check the headphones remove the batteries and connect up some none rechargeable battery of the same voltage to the headphone battery connections. To check the batteries use a multimeter to measure the voltage at their terminals while they are out of the headphones. If its low compared to the value printed on them, you can either try more new batteries again, or replace the headphones completely.
Televison &... | Answered 7 hours ago
Even though it's late now. Just change batteries. It worked with mine.
And Merry Christmas
-Ernestinaxx
Power board failure (bad cap etc)
Televison &... | Answered 9 hours ago
Hello, again, Garth -
You may find this article about reporting problems with Showmax informative:
https://mybroadband.co.za/news/broadcasting/144045-showmax-not-working-right-this-is-how-to-report-problems.html
The article gives an email address you can use to report problems you have with Showmax.
Best wishes.
Televison &... | Answered 16 hours ago
If you want to eject the CD you need to look on the front of the Blu-Ray drive for a small hole, about the size of a pencil-lead. If you open a paper clip and insert it, it should pop the drive open for you.
Televison &... | Answered 18 hours ago
Generic Memory PCI USB and Firewire Combo Card (sd-cb5271b-4e6i) Logo
Popular Tags
8 questions posted
Top Generic Memory Televison & Video Experts
Marvin
Marvin
Are you a Generic Memory Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Generic Memory Televison & Video
Most Popular Question
sd card not recognized in computer
  • Televison & Video
