20 Most Recent BenQ G922HDAL 18.5 WIDE LED MONITOR Questions & Answers
check the cable, wiring harness, check the outlet for power, make sure you do not have it is a plug that may have switch some where where it turns or shut the power to that outlet.
or can it be video card issue, or plugs adapter is faulty, try a different outlet or different plug in your power strip. check the power strip if you have one, make sure the power strip is on, push the reset button on the power strip.
if you motherboard has internal vga adapter try setting resolution to the lowest setting plug you monitor into the motherboard to see if the issue is the video card or cards.
turn monitor off and on see if it getting warm.
the resolutions maybe to high try lower setting temp.
see if the monitor has manufactures restore or reset button on the monitor some where, it would be around all the connectors are located.
does the light comes on when you turn on in the front of monitor.
if all fails than it is time for a new one.
thank you rod
BenQ G922HDAL... | Answered on Mar 03, 2015
Restoring your Joybook to factory default
settings:
This process will ERASE ALL data on your system drive C: and
restore the system to the default factory configuration.
If this option is selected, all programs you installed or data you
saved on the C: drive will be erased. However, data on the D:
drive will not be affected.
a. To restore your Joybook to its factory settings, click
Full System Restore - Factory default settings under
the Restore tab.
b. Follow the on-screen instructions to complete the task.
BenQ Computers &... | Answered on May 05, 2020
Go to settings >> system >> About device. Find "Build number" and click 6 times fast on it. Now go to Developer options >> Drawing Section or Rendering Section >> Find "Turn off hardware overlays" or "disable hardware overlays" >> This will force the phone to always use GPU for screen adjustments. no more flickering.
BenQ Computers &... | Answered on Feb 10, 2019
Obviously changed something. Check to make sure you haven't inadvertently muted the speakers. Go on your computer in the sound settings in control panel (manage audio devices) and ensure you have them set right.
BenQ Computers &... | Answered on Nov 19, 2017
you must repalce the CD Reader by the CD/DVD Writer , so you must buy it and change the old hardware -CD Rom Reader-
BenQ Computers &... | Answered on Jun 04, 2017
Follow the directions on this site:
http://www.gilsmethod.com/how_to_resolve_unknown_device_problems
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
BenQ Computers &... | Answered on May 31, 2017
BenQ G922HDAL 18.5 WIDE LED MONITOR Logo
1 questions posted
Top BenQ Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • BenQ Computers & Internet
Most Popular Question
power but monitor not come
  • Computers & Internet
