20 Most Recent Gigabyte 7VM400M-RZ (GA-7VM400M-RZ) Motherboard Questions & Answers
2answers
Dvd player
hi , can u be specific, do u mean the DVD rom or the DVD software player to run dvd's???let know
6/3/2022 12:07:50 PM • Gigabyte... • Answered on Jun 03, 2022
Had 512mb ram installed in each slot and one day
Your motherboard is quite old. It could be the RAM slot is simply dirty(use canned air), but if that's the case, the PC doesn't boot. The memory controller could be dying(replace motherboard or upgrade system). There could be other issues but it sounds like your memory itself is fine. You could try reinstalling the BIOS, but because of the age of your computer, you shouldn't spend any money trying to get it fixed. It would probably be cheaper just to get a compatible used motherboard on eBay as replacement. The better long term financial decision would have to be building either a used parts PC (because CPUs have barely gotten better in the last 5 years) or a brand new system. This isn't very much information to draw on, so if you can update your information, I can help more.
10/24/2017 5:11:22 PM • Gigabyte... • Answered on Oct 24, 2017
Hello Sir, When SMPS for motherboard burnt, all
Get a good used mo bo on ebay to replace the one you have. Make sure you get the exact replacement and it will go right in and you will not have any hassles with compatibility/driver issues. Lot cheaper!!!!!!!!!!!!!!!!
3/21/2017 3:34:21 PM • Gigabyte... • Answered on Mar 21, 2017
0answers
2answers
The computer won't start up
does the computer put anything on the screen? does the computer one beep after self test? what kind of lights or no power at all any errors. windows boot up problems
7/17/2015 8:53:25 PM • Gigabyte... • Answered on Jul 17, 2015
The AC97 on Motherboards after new Windows
You should say what version of Windows. The AC97 chipset is so common that it must be supported. Many Windows XP drivers will work for Windows 7. You must unpack the driver files and select it manually from device manager.
10/29/2013 12:14:32 PM • Gigabyte... • Answered on Oct 29, 2013
My problems is sound driver download
first you check sound is mute or not if the complaint is still there then goes to my computer-> properties->device manager-> hardware, if a question mark in the sound driver then u can download it from company site before downloading sound driver you have to verify your laptop model number & model name then then type it in the site(service & maintains section) after download you can instal it in the computer by click RUN-> next-> finish, through this way you can solve the problem
10/1/2012 6:38:41 AM • Gigabyte... • Answered on Oct 01, 2012
When powerd up i get 1 long beep after another,what could it bve?
Each motherboard BIOS has a series of beeps meaning different things. If you are getting two long beeps then I recommend looking up in the pdf manual in the FAQ or troubleshooting section of the guide. It could be anything like a heatsink not properly inserted, or the cpu cooler fan is broken or not plugged in, the memory needs reseated, or graphics card is not compatible, etc.
1/2/2012 10:56:32 AM • Gigabyte... • Answered on Jan 02, 2012
I want to upgrade my CPU, can you please let me know what my board supports please
glen your board will take up to 2g of ram and cpu is 3200 with a 400 fsb that will max out your board that should do it for you.jim
11/14/2011 11:37:46 AM • Gigabyte... • Answered on Nov 14, 2011
I am upgrading my pc & would like to know the best CPU to use
2g ran 3200 fsb cpu jim
11/14/2011 11:27:15 AM • Gigabyte... • Answered on Nov 14, 2011
Can you please advise the best CPU for my motherboard as I am upgrading my pc
your board gose too 2g a 3200 cpu with 400 fsb is the max you can go jim.
11/14/2011 11:26:12 AM • Gigabyte... • Answered on Nov 14, 2011
Motherboard GA-7VM400M 512 mb ram DDR upgrade
Already upgraded RAM to 2gig want ti upgrade CPU unit
11/11/2011 1:15:22 PM • Gigabyte... • Answered on Nov 11, 2011
I NEED TO KNOW WHERE
You can find all the jumper information in the Gigabyte 7VM400M-RZ mainboard manual.
9/6/2011 9:23:47 AM • Gigabyte... • Answered on Sep 06, 2011
WHAT RAM TO USE? IHAVE
Your motherboard supports DDR333 (PC2700) so i would not try 3200 if its not noted on their homepage.
http://www2010.gigabyte.com/Products/Motherboard/Products_Overview.aspx?ProductID=1764
5/10/2011 6:19:39 AM • Gigabyte... • Answered on May 10, 2011
What hard drive do i need ? sata/pata?
you need an IDE harddrive UDMA ATA133/100/66
2/8/2011 7:48:08 PM • Gigabyte... • Answered on Feb 08, 2011
Hi, in my computer properties,it
This is Gigabyte Support > 7VM400M-RZ motherboard > Main support page,
http://tw2005.giga-byte.com/Motherboard/Products/Products_Spec_7VM400M-RZ.htm
In the small chart in the middle where it states, Overview, Awards, BIOS, Comparison Sheet, CPU Support List Driver, FAQ, Manual, and News, click on > Driver.
(AMD Sempron 2400+
That fits in a Socket A processor socket. Socket A is also known as Socket 462.
Click on Manual for the motherboard manual)
11/24/2010 8:09:19 PM • Gigabyte... • Answered on Nov 24, 2010
Sir, my motherboard processor fans works ,if this
Open ram Slat remove ram clean ram reinstal deos not work
Buy new Ram reinstal Proble finsh
10/27/2010 3:11:00 AM • Gigabyte... • Answered on Oct 27, 2010
I am having a Problem
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps
10/18/2010 11:01:11 PM • Gigabyte... • Answered on Oct 18, 2010
All drivers needed for windows
If you where going to use this machine on the internet, windows 98 is not supported any more, and is not secure/safe.
I would advise at the very least windows 2000..
But your drivers are here if you want them.
http://www.giga-byte.co.uk/products/product-page.aspx?pid=1764&dl=1#driver
9/16/2010 3:17:49 PM • Gigabyte... • Answered on Sep 16, 2010
Gigabyte 7VM400M-RZ (GA-7VM400M-RZ) Motherboard Logo
58 questions posted
Top Gigabyte Computers & Internet Experts
Steve Nordquist
Steve Nordquist
MegaByteMe
MegaByteMe
Steve
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gigabyte Computers & Internet
Most Popular Question
512mb ram installed in each slot one day
  • Computers & Internet
