20 Most Recent Casio KL-60 label maker Questions & Answers
Hello, If you can't get it to work, try to do a factory reset.
Turn the unit off, then Hold the PRINT and ESC key down and then Press the power button. KEEP HOLDING THE Print and Esc key down for 2 seconds and then release both of them. You should see a message in the display INT?, Press SET to Reset your printer, or Esc to cancel.
Hope this helps.
Best wishes
Mac =)
Casio KL-60... | Answered on Mar 13, 2014
Hi, If you can't get it to work, try to do a factory reset.
Hope this helps.
Mac =)
What is the error you get ?
Casio KL-60... | Answered on Oct 25, 2013
Seems to be a common problem on this otherwise great calculator that helped me through both high school and university. I've had mine for nearly 20 years and this problem showed up a few years ago. But I remember classmates reported the same problem when it was almost new.
If replacing batteries isn't helping, the problem is most likely caused by oxidation on the springs connecting the battery holder to the main PCB. The solution is as follows:
1. Remove the metal back cover (2 screws)
2. Remove the plastic back lid by removing the black screws (leave the batteries mounted) and CAREFULLY slide the back lid to the lower end (where the EXE button is located). Do not lift while sliding until the lid easily comes off.
3. On the back side of the plastic lid, very carefully bend the the two metal connectors ~1 mm on both batteryholders to increase their tension.
4. Clean the connecting pads on the PCB and the metal springs with de-oxidizer solvent.
5. Re-assemble and your 4500P calculator should be good as new.
Casio Office... | Answered on Jun 30, 2020
Press the Shift/Mode key and set the Input/Output to MathIO.
Even that will not guarantee that the display will be in root form. Only square roots are possible.
Casio Office... | Answered on May 25, 2020
https://support.casio.com/en/support/answer.php?cid=004004001006&qid=103&num=1
The "E" stands for "Error". This problem can usually be resolved by resetting your calculator. https://sharpcalculators.com/support/troubleshooting/16-troubleshooting/39-what-does-the-e-on-my-display-mean-2
Casio Office... | Answered on Apr 11, 2020
I dont believe there is a grand total on that machine.
http://support.casio.com/en/manual/manualfile.php?cid=004005001
Casio Office... | Answered on Dec 06, 2019
Casio KL-60 label maker Logo
6 questions posted
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Casio Office Equipment & Supplies
Most Popular Question
get manual download misplaced manual
  • Office Equipment & Supplies
