20 Most Recent
Westinghouse " 40"" Class - LCD - 1080p - 60Hz - HDTV VR-4090" Questions & Answers
Westinghouse VR-4090 black screen. when you plug
Hi,I think not problem in power section. If you are used computer then this types of problem create, then you hdd damage or may be RAM also damage. So plz check you computer hardware device then you find what is you?
Service center in dubai
All type and all type repair is availble in Dubai at just one little call/email/msg - +97145864033 , info@
uaetechnician.com . Amazing experience
computer repairing near me and prompt service. Nevertheless, since our laptops and computers are so expensive, we should always opt for a better alternative.
How to fix code h19 on Westinghouse dishwasher please?
This is not an error code you have accidently activated the delay timer. This timer delays the start of your wash programme & can be set between 1 & 24 hours so a wash can be done overnight or when at work for example.
To deactivate the timer press the delay timer button until it shows '00' (sometimes +/- buttons)
LCD Computer monitor as a TV monitor
It could be used as a monitor if you have on of thoose advanced Digital Tuners, They usually have a DVI or VGA port.Especially the HDTV ones. Connect thoose and you're off. If your monitor supports TV tuning, just connectt eh cable straight away and you should be able to watch TV. I would use digital tuners since they are becoming Widely avaible.
How do I program a Westinghouse KPL 5500 security system
westinghouse the security system the system is beeping when i disconnect it shuts....Download the manual. I can't remember if it is in the User's Manual or the Programming Manual but a sequence to reset the security code is detailed in one of them. Also, it sounds like the telephone line was wired through the system for full seizure. To defeat this, you will need to take it out of the phone lines at the outside telco box. How it is wired is that the alarm panel intercepts the telephone line first and then feeds the circuit back out to the main junction where the telco comes into the house
