20 Most Recent
Sharp XE-A102 Cash Register Questions & Answers
How to set date and time onxe-a102 cash register
turn key to PGM then for Date enter MMDDYYYY press CA button (example) 09282012for time enter hhmm press CA button (example) time must be in military time increments for example 11:00PM will be entered as shown (2300).2300 hours will showupon your receipt as 11:00 PM. If you have any problems with SHARP equipment call 1-800-BE-SHARP.
Sharp HT-SB140 Sound Bar Internal PSU died
The Sharp HT-SB140 Sound Bar's internal PSU provides a DC output voltage of 19 volts. So you would need an external power supply that can provide a regulated DC voltage of 19V with the same or higher current rating as the original power supply.
When replacing the internal power supply with an external one, it is essential to ensure that the polarity of the output connector matches the polarity of the soundbar's internal PSU. The PW390-070 EF25 MF 1945 part number indicates that the power supply has a center-positive barrel connector. Therefore, you need to make sure that the replacement external PSU also has a center-positive connector.
It is also essential to make sure that the external power supply you choose can provide the same or higher power rating as the original internal PSU to ensure proper operation of the soundbar.
