20 Most Recent Sharp XE-A106 Cash Register Questions & Answers
0answers
Why is it frozen with letter L.000000000001?
Usually caused by flat batteries
3/27/2016 4:13:27 AM • Sharp XE-A106... • Answered on Mar 27, 2016
How to remove an f on the screen and no buttons will work?
sound like mite have control board problem beside the fault code, replace the control panel then solve the fault code Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/5/2016 7:28:20 PM • Sharp XE-A106... • Answered on Mar 05, 2016
0answers
Receipt cannot print out
Make sure the ink roller has not dried out and is inserted correctly. If it is ok, the printer is probably faulty. These tiny printers do not last more than a couple of years under normal use.
10/17/2015 1:12:12 AM • Sharp XE-A106... • Answered on Oct 17, 2015
Print is blurry and faint. I have replaced ink roller numerous times.
Usually caused by the rubber perishing on the print wheels or the hammer mechanism failing. These printers don't last a long time. They are very cheap for a reason. You could try cleaning the rubber print wheels but normally, the whole printer would be replaced
4/22/2015 1:58:48 AM • Sharp XE-A106... • Answered on Apr 22, 2015
0answers
Program key is staying on with cash register, register will not accept any transaction
YOU did not exit from progamming you where doing. Turn your key back to P and press Sub/total buttton to exit then back to reg and operate
5/16/2014 9:14:51 AM • Sharp XE-A106... • Answered on May 16, 2014
Sharp xe-a106 cash register e beep in department key
you are not logged in
4/23/2014 8:20:22 AM • Sharp XE-A106... • Answered on Apr 23, 2014
The tap will now feed
Properly close the head cover
4/23/2014 7:59:48 AM • Sharp XE-A106... • Answered on Apr 23, 2014
Paper will not feed
It could be that the cover is not in the rightful position . Push the cover hard down or you feed gear is worn then you need to replace it
4/23/2014 7:59:06 AM • Sharp XE-A106... • Answered on Apr 23, 2014
Won't stop printing
YOU are not logged in. Press 1 then # button
4/23/2014 7:57:11 AM • Sharp XE-A106... • Answered on Apr 23, 2014
Sharp XE-A106 Cash Register Logo
Popular Tags
61 questions posted
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Ekse
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Retail Supplies
Most Popular Question
change tax rate sharp xe a106
  • Retail Supplies
