20 Most Recent
450 Amp Battery Jump-Starter Questions & Answers
User manual stanley fat max pprh5kl
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiVqqjegOKBAxXu7bsIHfVMB6kQFnoECBEQAQ&url=https%3A%2F%2Fmanualzz.com%2Fdoc%2Fen%2F22113361%2Fstanley-pprh5-500-instant---1000-peak-battery-amp-profess...&usg=AOvVaw0zwq6sg4I8mvSlZgdTiI-x&opi=89978449
Battery state light stays on & discharges battery
something not right here with the question/request---""unplugging the 230 volt charger"????--I don't know of a 230 volt charger---unless this is in Europe---a 120 volt charger---in USA-- but I'll try this---a LED light does not use enough electricity to discharge a battery over night--- do you have another function on this unit such as a compressor or lights--something that maybe on???---another thought is that the battery has failed causing this malfunction----has this been wet/underwater---a malfunction with a diode in the electronics may cause the charger to try and charge the battery via ac and cook the battery as well as the circuit board---this is a real issue here---I'm not getting enough info to give an intelligent answer---i need to know if anything has happen what has happened before and up to this point when this issue started---I don't know what happens if when using these units if you connect to (jump start) battery with reverse polarity--if it bows a fuse or cooks the unit---sorry I can't be more helpful
The on off switch broke off
You can dissemble the unit and replace the switch---it's usually a common type switch that you could pick up a radio shack or graingers---also you could go to the Stanley web site for a diagram and listing of the parts-number----then order from them--hope this helps
The part that you put on the valve stem is broke ,how do i fix it
I would go to Stanley web site and check for a diagram of the item and see if it lists the part you need----you could also go to auto parts store and get the end that used for inflating tires on tire machine and put it on your hose---you may have to buy an adapter for the hose and clamp then screw the end on----hope this will help
Can you leave it plugged in
Since most of those chargers are just simple current chargers it is best to not leaving on it all the time. Plug the charger in to the Jump Starter for about a day or two and then unplug it. About a week later plug the charger in for a day, then unplug it and do it again next week.
How do I charge this?
You've probably figured this out by now, but their should be a thing that looks like the male end of an electrical plug in an odd place. Get an extension cord and place the female end over that male end and plug the male end of the extension cord it into the wall overnight.
