20 Most Recent Android Gemini Tab Questions & Answers
probabely it has a problem from screen cable inside or lcd
Android Gemini... | Answered on Aug 09, 2018
The Gemini tablet line performs factory resets and firmware updates with an SD card. Performing a factory reset requires writing files to an SD card with a computer, then starting up the tablet with the SD card present in it. Be aware that it will erase all data on the tablet, but with it in a boot loop, that may be a moot point.
Knowing the specific model number of your tablet is critical. Flashing the incorrect information can cause worse problems than you are encountering now. Rather than send you to the D7 GEM7007 page, I will give you the general page that leads to all the possible tablet results and directions. Look for the link that matches the Model Number, not just the name.
Factory Reset Original Firmware ROM Image Flashing Instructions
You will most likely need:
An SD card appropriate for the tablet (SD, MicroSD, Etc)
A reader for the card for your computer (Attached reader will handle SD and MicroSD)
The ability to get the Tablet to completely turn off to start the process.
The first two can be purchased. The last one is up to whether the tablet has a hardware fault. If the tablet has any kind of broken hardware inside it (wear and tear, aging, or damage) the process may not work. In the event of hardware failure, replacement under warranty or without warranty may be the best solution.
Android Gemini... | Answered on Apr 25, 2015
Try this, i have hope that it can work,
long press the off key button, and some options will appear and one of the options is the off.
Android Gemini... | Answered on Feb 12, 2015
there is usually a reset button somewhere on the unit, try that
Android Gemini... | Answered on Feb 10, 2015
Hello chloe you ned to free some of the memory by closing all resent used apps and IF the tablet is unresponsive you may be requierd to perform a hard reset your tablet
Resetting your device to Factory Defaults If you need to reset your device to the factory default settings for any reason please follow the process below:
WARNING!!!
Please be aware any information currently on the device will be permanently erased by following this procedure.
  1. Go to applications screen and touch the settings button.
  2. Touch the Backup & reset option.
  3. Select Factory data reset.
  4. Leave the erase SD card option unticked & touch "Reset tablet".
  5. Touch "erase everything".
  6. The unit will now reset itself back to factory reset and any previous information/data will have been permanently erased.
Getting further help and support
Please see our support site below for further help and support with your device including how to install software updates if available and much more:
http://getsatisfaction.com/geminidevices
Manufakturer
http://www.geminidevices.com/7030.html
manual
http://www.geminidevices.com/manuals/GEM7030-Manual.pdf
Android Gemini... | Answered on Jan 13, 2015
Hi Carol,
You need a charging cable with a USB port at the end of it. You can then plug that charger into any USB port on the computer so charge your tablet.
Let me know if this helps,
Thanks,
Hunter Quinn
IBM Technician
Android Gemini... | Answered on Jul 15, 2014
This happens automatically when Google makes it available You will see a notice on your device. Some older devices like the 1st and 2nd generation Nexus 7 are not being updated now at all.
You can check for availability of an update.Follow this
http://www.dummies.com/consumer-electronics/tablets/android-tablets/how-to-update-your-android-tablet-system/
Android Tablets... | Answered on Jan 02, 2020
If you have a netflix account, you can use the netflix app. Or if you are an xfinity user, you can download the xfinity tv app, sign in with your details and youre good. Now if you want to watch movies added on your phone, you can download the VLC app. But if the movie format is not supported like the mkv format, you might need to convert them.
Android Tablets... | Answered on Dec 20, 2019
My MiTraveler 10C3 OS: Android 4.0 is stuck on logo and can this be fixed.
Android Tablets... | Answered on Dec 17, 2019
Android Gemini Tab Logo
27 questions posted
Top Android Tablets & eReaders Experts
Mr.Mike
Lawrence Oravetz
Phil Whisenant
Phil Whisenant
Are you an Android Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Android Tablets & eReaders
Most Popular Question
granddaughter forgotten unlock pattern
  • Tablets & eReaders
