20 Most Recent Smeg A2.2 Gas Kitchen Range Questions & Answers
may be thermostat or control card
Smeg A2.2 Gas... | Answered on Apr 26, 2010
It sounds like you have a hot wire going to ground (earth) and your oven is protecting you as it should. Finding the problem will take a little know how and I would advise you to find a serviceman or friend with some electrical experience to check it out. Someone could try and talk you through it, but that would be an unsafe option.
Smeg A2.2 Gas... | Answered on Jan 04, 2010
Yes you can. I am a licensed electrician and have seen it happen several times. However, if you replace the fuse and it blows again stop and check to see if you have a ground problem. You will need a volt/ohm meter to do this. Any hardware or Walmart will have a cheap one, which is all you will need. Most ovens in the home are 240 volt ac. You may have a three or four wire systems depending on how old the unit is. One wire is a ground, and is a protection wire that will trip the breaker or blow the fuse instead if shocking you if any power goes to the outer case.. It is usely green or yellow with a green stripe. In older units it also was used as a return for the 120vac devices on the unit (Lights, Controls, etc.) This wasn't very safe and new units have four wires, one dedicated to the return line.
All that said, you check it by first unplugging the oven and turning the breaker back on or replacing the fuse. If it doesn't trip or burn out, plug the unit back in. If nothing goes wrong you are good to go. If it does trip, call a service man of frind with an electrical background to check it out. Most oven problems are not that hard to fix, just expencive depending on the part.
If the stove is vented to the outside, it may be just drawing air from the room through the fan.
Smeg A2.2 Gas... | Answered on Jan 17, 2009
please write the M# so ican help you
Smeg A2.2 Gas... | Answered on Mar 12, 2008
whilst alarm is ringing press the minus (-) button. there are 3 volumes to choose.
Smeg Kitchen... | Answered on Feb 04, 2019
Mostly when you can light up the pits without the clicker, then that means that there is no power on the stove at all. Check the power cord running to it (which generate the sparks) and see if there is any damage to it.
Smeg Kitchen... | Answered on Jan 16, 2019
Check the regulator at your gas bottles may need replacing
Smeg Kitchen... | Answered on Nov 18, 2018
even stainless steel will tarnish with the heat from the flame
all metal discolours with heat so the cleaning products will only be to remove spilt food etc from the hob
Smeg Kitchen... | Answered on Aug 14, 2017
Smeg A2.2 Gas Kitchen Range Logo
18 questions posted
Top Smeg Kitchen Ranges Experts
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
Smeg Kitchen Ranges
  • Smeg Kitchen Ranges
Most Popular Question
replacing front panel
  • Kitchen Ranges
