20 Most Recent OEM Systems Dell Inspiron N5010 N7010 Xps 15 Blu-ray Optical Drive Dvd-rw Bd-rom Ct30n Questions & Answers
Make sure you run the installer as an administrator and disable anti-virus software as it is likely to need to make changes to your hard drive to allow the BR drive to be recognised as a boot drive.
Navigate to the installer program but right click on it first and select "Run as Administrator", even if you already have administrator rights. Windows is weird like that.
Good Luck
OEM Systems Dell... | Answered on Jun 18, 2014
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
OEM Systems Dell... | Answered on Mar 10, 2013
this device have many spekers..... none of them works??? do you have volume up??? check if you have no mute button depressed....
check if all speakers are connected to proper connectors....
check users manual, there are always pars, that describing what to do, when problem like that appear... try factory reset
OEM Systems... | Answered on Mar 27, 2014
Most likely your problems is related to driver, especially sound driver. To double check if all the drivers is installed properly, go to: Computer > Right Click > Then select Manage > In the drop down menu on the left choose "Device Manager"
It should show what driver is installed and not yet installed. Do look up your driver at Emachines website for any download. After all driver is installed do reboot the computer.
OEM Systems... | Answered on Nov 18, 2013
It is obviously dying or incapable of supplying a sufficient flow of power to the system. Before it blows, you will want to buy yourself a new one to prevent losing other components within your system. You can find some very good power supplies at this website. Once the page loads, search for: PC Power & Cooling. After the page loads, select, "PC Power & Cooling" on the left under the category, "Manufacturer."
Make sure you find one that exceeds your power needs by about 100-150 Watts. Yes, they are expensive, but you DO NOT want to skimp on the most important aspect of the computer, power. Wen it comes to power, you get what you pay for. Almost all cheap power-supplies will last you one year and then blow. And once they blow, they frequently take other components with them. Components such as motherboards, memory, CPUs, and Video Cards.
The reason behind picking a PC Power & Cooling PSU is rather self-explanatory. Firstly, they have the highest efficiency rating of any single-rail PSU. Secondly the PSU tends to run cool, thus increasing its life span. Thirdly, they are reliable and provide a steady flow of power. All of this equates to a great power supply which will support your system for a long time.
Let me know if I can assist you further or if I need to explain anything mentioned above in more detail.
OEM Systems... | Answered on Mar 25, 2009
WOULD ASKING QUICK BOOKS BE EASIER
Computers &... | Answered 10 hours ago
The error code 0xC004f074 will occur when a user has downloaded an ******* (pirated) version of the Windows operating system.
Well, there are several things that you can try to fix this: 1. Try hitting the "reset button"(the little tiny one in the hole) with a paper clip;this should unfreeze it (in light of the fact that there are not any other problems). If this does not work try: 2. You can try pressing the lock/unlock button the side 3. You could also try plugging it directly into your computer with the USB cable. 4. Hold the power button down when you turn it off for no more than 30 seconds; Turn the device back on. 5. You could have done the initial set-up incorrectly. Make sure that it is 7" on 7", 8"on8", etc. 6. Try the install with a different ption 7. Drain the battery completely until the system goes dead on it`s own, take the battery out for about five minutes, and then put the battery back in. (NOTE: When you take the battery out, hold down the volume buttons for about 5 seconds).
Computers &... | Answered 13 hours ago
The issue you're experiencing might be caused by a variety of issues which we need to find out. It would be better if you could provide mini dump file and also answer the following questions:
Which Windows 10 build are you using?
Can you send us a screenshot of the error message you're getting?
Can you provide us a detailed description of the issue you're experiencing?
Did you make any changes before this issue happened?
If not, you can refer to the following solutions:
Fix: Thread Stuck in Device Driver Error [16 Solutions]
Computers &... | Answered 14 hours ago
there is an iOS emulator called 'Cycada' which let you run some iOS Apps on a newer Android phone....
- however I recommend to switch to a real iPhone....
Cycada Native Execution of iOS Apps on Androidios-andriod-uhzcsljfm1hzx2k33uket32a-4-0.jpg
Computers &... | Answered 19 hours ago
now this is down right dangerous asking for someone to get you your password, you can reset your password via the email manager your using
Computers &... | Answered Yesterday
OEM Systems Dell Inspiron N5010 N7010 Xps 15 Blu-ray Optical Drive Dvd-rw Bd-rom Ct30n Logo
Popular Tags
2 questions posted
Top OEM Systems Computers & Internet Experts
Lucky
Bill Boyd
Dayton Computer
Dayton Computer
Are you an OEM Systems Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • OEM Systems Computers & Internet
Most Popular Question
force windows install manufacturers
  • Computers & Internet
