20 Most Recent
Smeg S43KIT3750EB Microwave Oven Questions & Answers
How to set the clock please?
One of these sequences may work:
CLOCK > 1
> 2 > 3 > CLOCK
CLOCK > 1
> 2 > 3 > START
CLOCK > CLEAR
> 1 > 2 > 3 > CLOCK
CLOCK > CLEAR
> 1 > 2 > 3 > START
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer
5/30/2010 6:00:54 PM •
Smeg...
Answered
on May 30, 2010
Smeg Microwave Components
Generally speaking, light bulbs can be had from common sources such as department stores, home improvement stores, and hardware stores.
Of course, I don't know much about what you'd call those places "down under and over a bit", but I'm sure the terms will translate well enough. *grin*
4/26/2009 7:05:04 AM •
Smeg...
Answered
on Apr 26, 2009
Lost the manual
Smeg's user manual link:
http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN
2/25/2007 10:20:30 PM •
Smeg...
Answered
on Feb 25, 2007
Smeg microwave convectio/grill oven model SA987CX does not preheat
If your microwave oven doesn’t heat, you may have a problem with the high voltage diode or rectifier. This component helps provide the high voltage that powers the magnetron. The high voltage diode is located near the magnetron and the high voltage capacitor, so access will require removal of the cabinet. Disconnect the power and also discharge the high voltage capacitor to prevent an electrical shock. You can then test the diode for continuity with a multi-meter. Diodes are polarity specific and you should see low resistance with the meter leads in one direction and higher resistance when the meter leads are reversed. Most multi-meters will have a special setting for diodes or rectifiers. If the high voltage diode shows low resistance in both directions or shows no continuity at all, then it will need to be replaced. If you find the high voltage diode tests okay, then you will need to determine whether power is being supplied to the circuit. This is a high voltage circuit and further testing should only be performed by a qualified technician.
