20 Most Recent Nikon FM10 35mm SLR Camera Questions & Answers
Nikon FM10 will only release shutter with cable
Hello Blair, I too like old school camera, mine are the N2000, N6006, N80, and F100. First without film in the camera I would attempt to release the shutter. If it does then there is something going on with the film transfer causing a bind. However, If it continues not to release the shutter I would put the FM10 on the shelf then go to KEH.com for another. Just now checked KEH.com, 2014-05-26, a FM10 in EX condition is $89, EX+ condition $99. That would be a much better move than repairing yours and less expensive. Cordially
5/7/2021 7:50:09 AM • Nikon FM10 35mm... • Answered on May 07, 2021
Minolta x700 winder broken off camera
needs repairing at a qualified shop when was it last cleaned or serviced ? if you think the camera is worthy, since its old how much is it worth to you vs a new one
2/13/2015 4:20:50 AM • Nikon FM10 35mm... • Answered on Feb 13, 2015
I have four Nikon FM 10s that all seem to have the
Nope, needs repairing at a qualified shop
2/13/2015 4:08:59 AM • Nikon FM10 35mm... • Answered on Feb 13, 2015
Will using a higher voltage battery harm my camera?
YES dont do it
2/13/2015 4:02:36 AM • Nikon FM10 35mm... • Answered on Feb 13, 2015
Shutter is broken/cracked
Yes, needs repairing at a qualified shop
2/13/2015 4:00:47 AM • Nikon FM10 35mm... • Answered on Feb 13, 2015
Advance lever will not advance
2/13/2015 4:00:15 AM • Nikon FM10 35mm... • Answered on Feb 13, 2015
Shutter is stuck. Mirror is also stuck.
Comon problem, If the self-timer is advanced and relaese button won't release then it needs repair shutter bad,
1/16/2015 9:33:43 PM • Nikon FM10 35mm... • Answered on Jan 16, 2015
Nikon FM10 Camera will only work with cable release
Release switch needs to be repaired
7/31/2014 4:14:09 PM • Nikon FM10 35mm... • Answered on Jul 31, 2014
I have taken 2 rolls of film to be developed and
Hi Carrie, A number of things could be the cause, camera and processing. If it is C41, negative film, we will rule out processing. Another thing is your camera may not be setting the exposure correctly. Are you setting the exposure manually or automatically? With the camera in automatic exposure open the back, point to a bright spot press the shutter, do you see light? Then Set the camera to one second, and at the widest aperture, say f2.8, open the back press the shutter, now do you see light? Depending on the results you will need to decide if the camera is worth repairing or a new/used one is in your future. Cordially
5/26/2014 11:26:23 PM • Nikon FM10 35mm... • Answered on May 26, 2014
Where is serial number nikon fm 10
I can't speak to the FM10 specifically, however nikon has a few standardized positions for the serial number. It may be embossed in in small numbers on the metal at the top back above the film door. Or on the bottom. If you can't find it, I would go to the Nikon USA website. You can e-mail there support department by following this link: Contact Nikon Customer Service Call Nikon Technical Support
3/14/2014 5:56:01 AM • Nikon FM10 35mm... • Answered on Mar 14, 2014
2answers
Nikon FM10 Winder came out
Not sure exactly which piece you mean, but take a look at http://uscamera.com/fe10-fm10.htm
12/21/2013 5:14:56 PM • Nikon FM10 35mm... • Answered on Dec 21, 2013
No pictures on film when we take it in to be
If the "edge numbers" are present on the developed film it is not a processing error. Most likely the film is not advancing, film was not loaded properly of the shutter is not working.
12/21/2013 5:04:05 PM • Nikon FM10 35mm... • Answered on Dec 21, 2013
0answers
manual
Nikon FM10 35mm SLR Camera Logo
50 questions posted
Top Nikon Photography Experts
Steven Wander
Steven Wander
Marvin
Marvin
Steve
Are you a Nikon Photography Expert? Answer questions, earn points and help others
View Most Popular
Nikon Photography
  • Nikon Photography
Most Popular Question
nikon fm10 will only release shutter
  • Photography
