20 Most Recent Smeg FA311X Top Freezer Refrigerator Questions & Answers
If you hold your finger on the light the fan should come on if not you could have a bad fan motor, fan swith , or wiring
Smeg FA311X Top... | Answered on Mar 24, 2014
sounds like your door is sprung. take door off and lay flat on a table outside of the door down. loosen screws on door liner . screws are hidden under door seal. when all loose not removed make sure door is flat on table. tighten the screws being careful not to move door. reinstall door and it should be ok. this is usually cause be either someone leaning or hanging on the door when it is open. or putting to heavy of items in the door trays.
Smeg FA311X Top... | Answered on May 27, 2012
May be your damper switch not closing your damper when it reaches tempature setting.
Smeg FA311X Top... | Answered on Mar 30, 2008
It sounds like the thermostat is failing, or has failed. Try altering the temperature to make it warmer. If it has fully failed, altering will make no difference at all and it will be working constantly instead of cycling on and off to maintain the temperature you have set it to.
Put a thermometer in the top of the fridge and one in the bottom. Write down the temperatures first thing in the morning and at 6:00 pm.
Monitor the temperature for two days before you make the setting warmer.
You can also try turning the whole thing off for an hour as it may reset.
Smeg... | Answered on Aug 05, 2019
https://m.youtube.com/watch?v=5SzyciOAl6k
Smeg... | Answered on Mar 30, 2019
Hi not think you get a works Manual on taking it apart you only get a operating instructions Manual that is not going to help you take any think apart sorry.
Smeg... | Answered on Jan 09, 2019
General advice and videos on replacing fridge thermostats in the link. The Smeg thermostat sensor is under a plastic cover with a couple of plastic pegs holding it in.
smeg fridge thermostat removal Google Search
Smeg... | Answered on Jul 24, 2018
Smeg FA311X Top Freezer Refrigerator Logo
10 questions posted
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Mike
Andrew Taylor
Andrew Taylor
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Smeg Refrigerators
  • Smeg Refrigerators
Most Popular Question
fridge not cold enough build up ice back
  • Refrigerators
