20 Most Recent IBM Infoprint 1120 Laser Printer Questions & Answers
You can download the BM InfoPrint 1xxx AIX Print Driver from the IBM support WEB site. Please click on this link and select your model printer to download :- http://www-01.ibm.com/support/docview.wss?rs=95&context=SRATEW&dc=D400&uid=psd1P4000313&loc=en_US&cs=utf-8&lang=en
IBM Infoprint... • Answered on Dec 13, 2012
If you have a duplexer check in there. also sometimes the paper will get stuck in the fuser and will be torn off inside. you can take the fuser out with a phillips (2 screws) and and 2 plugs. check and rotate fuser by hand to be sure it is clean. re assemble
IBM Infoprint... • Answered on Mar 07, 2012
Just switch Off the Power and wait for 1 minite. this method will reset most printers
IBM Infoprint... • Answered on Jan 17, 2011
The problem is caused by one of the following (normally it's the cartridge that's faulty, very common on Lexmark's and IBM Infoprints)
The toner sensor is not operating properly, the developer
drive assembly is not operating properly or the print
cartridge is defective
IBM Infoprint... • Answered on Dec 21, 2010
This is actually a Lexmark printer, so what I'm quoting is a Lexmark sol.
turn off machine
hold down returnand go buttons
turn on printer
hold  until performing test shows and let go of buttons
it will go to a service mode ( instead of saying ready)
got to printer set up
hit select button
go to engine 1,2 or 3
try each one ( hit select to go into that perticular number)
what you are looking for is a number that has an * next to it. Use the arrow keys to scroll. most likely it changed the setting so go and look for that number w/the * and hit select when you see it.
IBM Infoprint... • Answered on Dec 14, 2010
try to search in the internet the driver of your printer
IBM Infoprint... • Answered on Oct 30, 2010
the power switch is on the rear bottom corner of the right-hand side. be sure you plug it in, and then flip the switch.
IBM Infoprint... • Answered on Oct 28, 2010
I have found over the years that printers usually don't lie. If it is saying there is a problem there usually is. Unfortunately they can't tell you exactly where to look.
I have found the following that have caused printer errors: - a small piece of paper has torn off and got stuck somewhere in the guts of the printer. The printer will register this as a jam and will not work again until this paper has been removed. I have had to tear out the guts of a printer just to find the tiniest piece of paper. -if you print labels that are the self stick kind sometimes a small piece of the label may become stuck to something and register as a jam. - there may be an issue with the paper standard bin or some other part. Make sure it is not overfilled. It cold be a roller issue or some other part that has gone bad.
Your best bet if you can't figure it out is to call for service.
First off try to disconnect the printer and uninstall the printer software. The reinstall and connect your printer for harware detection and final installation, Now there can be no errors as the printer must do the job. If not clean your head with the maintenance menu and try to test print. If this wont solve We must suspect the toner that was last replaced . Finally the head could be the last culprit in our list. Hope you check this out . Good day
IBM Infoprint... • Answered on Aug 13, 2010
you can download a copy for your IBM infoprint 1120 laser printer from here
Click here to Download
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
Manish
IBM Infoprint... • Answered on Mar 27, 2010
IBM Infoprint 1120 Laser Printer Logo
46 questions posted
Top IBM Office Equipment & Supplies Experts
Alan Matzke
Alan Matzke
efs_perpends
efs_perpends
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • IBM Office Equipment & Supplies
Most Popular Question
paper tray in printer but printer says
  • Office Equipment & Supplies
