20 Most Recent Honeywell Multimedia, Cat5e X2, RG6/U Qdx2-500ft (GNS50505105) Questions & Answers
Some testers do not test ALL the wires. Some will only test pair 1 and 2. You may want to use a DVM (Digital Voltmeter) set on the ohms function and check continuity on each of the eight wires from RJ-45 to RJ-45 connector or use a cable tester that will check all the wires. If you use a DVM check 1 to 1, 2 to 2 etc. for continuity. Good will read 0 ohms, open will read infinity or OL on some meters. 90% of all cable problems are poorly crimped or broken wires at the RJ-45 connector. It is difficult to be sure which end has the bad connection so you may need to change BOTH RJ-45 connectors. Do one, then check the cable, if it doesn't work, do the other one. It is a 50-50 shot. I prefer and encourage the rewiring color code using the EIA 568A standard. Starting at pin 1 the color code would be orange-white, orange, green-white, blue, blue-white, green, brown-white, brown. You don't have to do it that way, but you must make sure that the same color wire is on the same pin on each connector. If all else fails, you can go to you neighborhood computer shop for help in installing connectors. It takes a lot of practice to do it right. Hope this helps
Honeywell... | Answered on Feb 06, 2007
I became locked out of my honeywell HA-DVR-1104-S thermostat while trying to set the password, how can i unlock/reset it
Honeywell... | Answered on Feb 16, 2019
A power outage should not damage a thermostat. Try to reprogram all times and temps. You may need to disconnect power for a longer time to make it reset completely.
Honeywell... | Answered on Jan 21, 2019
remove the cmos battery , wait 10 seconds and put it back , then power on the dvr
Honeywell... | Answered on Jun 01, 2018
Please read the manual. Link attached:
https://www.manualslib.com/manual/1129455/Honeywell-Ade-Accenta-Gen4.html
Honeywell... | Answered on Apr 14, 2018
Pull the face plate evenly all the way around, it just snaps off the back plate screwed to the wall batteries are visible .
Honeywell... | Answered on Dec 21, 2017
Computers & Internet Logo
1 questions posted
Top Honeywell Computers & Internet Experts
Marvin
Marvin
Vebble
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Honeywell Computers & Internet
Most Popular Question
cat5e
  • Computers & Internet
