20 Most Recent
Motorola Mobility V3 Handsfree Headset with Connector fits MOTO Razr V3 Headset Questions & Answers
Motorola RAZR V3 problems with a Motorola H350 Bluetooth Headset
I do not provide the user manual, however, function of the H350 is very similar to the H500 and we are providing a link to the H500 user guide. Just copy and paste this link into your browser and Motorola will explain how to connect your Bluetooth Headset. http://telecom.hellodirect.com/eBiz/pdf/cellphoneheadsets/Motorola_H500_Manual.pdf
10/18/2008 9:45:56 PM •
Motorola...
Answered
on Oct 18, 2008
MMS PROBLEM
hello there ....its quite simple...you need to call the customer care of your network provider and ask them for "MMS Settings"...it is free...just keep the model number of your phone number handy (you will find that on the box in which you got the phone)...or the IMEI number (15 digits mostly) by dialing *#06# on your phone or beneath the battery or on the box near bar code....
that should solve the problem.....
you can also ask the for some free MMS ...many companies promote them....always good to try something for free before you start using it ...lol
hope this help
Cheers
10/15/2008 1:07:26 AM •
Motorola...
Answered
on Oct 15, 2008
Help
8/23/2007 2:54:20 AM •
Motorola...
Answered
on Aug 23, 2007
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
