20 Most Recent HTC Sensation XE Z715E Beats Audio Smartphone Unlocked Questions & Answers
follow this steps and fix it. God bless you
Check your connection. If your Bluetooth will not connect to your phone, it's possible that it isn't paired or has lost its pairing with your phone. Begin by powering off your Bluetooth by pressing the multifunction button located at the top of the device.
    • 2
On the Nokia 6555 press the center "Select" key, located in the middle of the circular navigation keypad. This takes you to the phone's main menu.
    • 3
Use the navigation key to scroll to "Settings" and press the center "Select" key.
    • 4
Scroll to "Connectivity" and press the center "Select" key.
    • 5
Scroll to "Bluetooth" and press the "Center select" key.
    • 6
Scroll to "On" and press the center "Select" key.
    • 7
On the main Bluetooth menu, scroll to "Search audio enhancements" and press the center "Select" key.
    • 8
The phone will automatically search for available Bluetooth devices. When you seen an icon that says "Philips SHB 1300," press the center "Select." Your phone will be paired or reconnected to your Bluetooth.
2. Dead Battery o 9
Another common and easy-to-solve Bluetooth problem is the headset's inability to turn on. A dead battery is the likely culprit here.
o 10
Plug your Bluetooth into the power cable that came with it.
o 11
Plug the power cable into a wall outlet.
o 12
Allow your Bluetooth to charge for three hours.
o 13
Recharging the battery will give you about seven hours of talk time or up to 200 hours of standby time before you'll have to charge it again
HTC Sensation XE... | Answered on Oct 29, 2013
I reckon yer phone is stuffed as there is a loose connection in the headset jack and thus the phone thinks there is a plug in there all the time. The only suggestion l can make is to get nail 3.5mm the size of the plug and stick it down the hole an give it a wiggle (at yer own risk of course ) this should shake up the connections an should be all good again.
HTC Radio... | Answered on Dec 04, 2017
Yes. HTC headphones are better than Sony nowadays.
HTC Radio... | Answered on Dec 31, 2014
Hello there! Assuming your talking about "XtremeMan SOMA BT" I'm not a fan of assumptions but... if this is the device your are referring to then here you go below. If this is not the device you are making reference to, then please respond with the model number and make/brand of the device. Thanks for your visit and good luck.
1. With the unit on or off, plug the included cable
from the USB jack on your computer to the micro
USB jack v on this unit. While charging, the
battery level will be shown by the LED indicators
with the current level LED blinking. When all
the LED indicators light solid, then the unit
is fully charged.
2. If the power level is less than 10%, the left-most
LED indicator will start blinking, which means
that the Soma BT needs to be charged.
Using the Soma BT with a Bluetooth Device
1. Turn on the unit as shown above.
2. Press and hold the Bluetooth button U for
approximately three seconds until a beep
sounds and the right-most LED starts blinking.
3. Within five minutes, select Soma BT from the
Bluetooth List on the external device. See
external device's owner's manual for details.
When paired successfully, the Soma BT will beep
twice and the right-most LED will light
https://www.manualslib.com/manual/1540329/Xtrememac-Soma-Bt.html?page=8#manual Check Here
Radio... | Answered on May 20, 2020
The meter is out of range! Move the meter closer to the main box.
Radio... | Answered on May 17, 2020
cut bluetooth on phone.. unplug alexa and tell her to turn of blue tooth on devices.
Radio... | Answered on May 06, 2020
T squelch and PTT on can be reset by button presses. It's shown in the manual, available for free online in various places.
Radio... | Answered on May 04, 2020
EMAILING THINGS IS NOT WHAT WE DO . IF WE ASSIST YOU WILL GET NOTIFICATION ON THE WEBSITE A BELL SYMBOL WITH A NUMBER ON IT AT TOP RIGHT CORNER .
Radio... | Answered on Apr 22, 2020
All you have to do is turn then off and when you're going to turn them back on keep pressing the power button until you hear bluetooth linking, it won't ask for a pin after that.
Radio... | Answered on Apr 21, 2020
HTC Sensation XE Z715E Beats Audio Smartphone Unlocked Logo
1 questions posted
Top HTC Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a HTC Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • HTC Radio Communications
Most Popular Question
bluetooth not working
  • Radio Communications
