20 Most Recent Panasonic iPalm PV-DC3010 Digital Camera Questions & Answers
2answers
Software
Both the PV-DC3000-A and PV-DC3010 come packed with ArcSoft® software which includes: ArcSoft PhotoImpression™ 2000 An easy-to-use photo editing program that allows users to edit, enhance, retouch or add special effects to any image. ArcSoft PhotoPrinter® 2000 PRO Allows users to layout their images in multiple sizes quickly and effortlessly. ArcSoft Panorama Maker™ Easy-to-use photo stitching program that seamlessly combines multiple photos into a single shot. ArcSoft PhotoFantasy™ 2000 (included with PV-DC3010 only) Create "personal fantasies" by combining your personal photos with a wide selection of included fantasy backgrounds. ArcSoft PhotoMontage™ (included with PV-DC3010 only) Create a montage of a single image from a collection of thousands of micro images.
4/11/2022 2:55:27 AM • Panasonic iPalm... • Answered on Apr 11, 2022
ArcSoft® software
No. These cameras store images in a JPEG or TIFF file formats and can be used with any software package that can open a JPEG or TIFF image.
8/31/2005 1:44:40 PM • Panasonic iPalm... • Answered on Aug 31, 2005
After one minute the LCD screen turns black
No. Panasonic iPalm cameras have a POWER DOWN feature to conserve battery power. If there is over one minute of inactivity, the LCD will power down to conserve the battery. Simply hit the SHTR button and the LCD will turn ON.
8/31/2005 1:42:41 PM • Panasonic iPalm... • Answered on Aug 31, 2005
DPOF Print Mark Function
The DPOF Print Mark Function allows you to sort through a memory card or disk and select the images you want to print by electronically marking them. You can then print the marked images on any DPOF compatible printer by hitting the AUTO PRINT button.
8/31/2005 1:42:10 PM • Panasonic iPalm... • Answered on Aug 31, 2005
Computers to use with iPalm™
Microsoft® Windows® 98, Windows® Me or Windows® 2000 PC with USB Port. Macintosh® with USB port and Mac OS version 8.6, 9.0 or 9.04 or later is required to operate this camera.
8/31/2005 1:41:34 PM • Panasonic iPalm... • Answered on Aug 31, 2005
Lens range
On a 35mm basis, the lens range is 32-64mm.
8/31/2005 1:40:41 PM • Panasonic iPalm... • Answered on Aug 31, 2005
Focusing range
12 cm to infinity.
8/31/2005 1:40:03 PM • Panasonic iPalm... • Answered on Aug 31, 2005
Shutter speed
The shutter speeds are as follows: 1/30 - 1/1,000 in AUTO MODE 1/4 - 1/1,000 in SLOW SHUTTER MODE 1/30 - 1/1,000 in MOTION MODE
8/31/2005 1:39:27 PM • Panasonic iPalm... • Answered on Aug 31, 2005
Storage path
On removable memory cards. Panasonic iPalm Digital Cameras are equipped with an SD Card Slot which allows the camera to store images on EITHER an MultiMediaCard (MMC) or an SD Memory Card. Simply insert an MMC or SD Card into the camera, take pictures until the card is full, then remove it or replace it with a fresh card. You can selectively erase any or all of the images from the either the MultiMediaCard or the SD Memory Card and reuse it. Storage capacity for the PV-DC3000-A (based on included 16MB SD Memory Card) SuperFine Mode* (2048x1536/low compression) up to 13 images Fine Mode (2048x1536) up to 27 images Normal/2x Digital Zoom Modes (1024x768) up to 69 images Burst Recording Mode (1024x768) up to 82 images 3x Digital Zoom Mode (640x480) up to 150 images Motion Image Recording Mode (12 sec. max./320x240) 9 sets TIFF Mode (2048x1536/no compression) 1 image Storage capacity for the PV-DC3010 (based on included 32MB SD Memory Card) SuperFine Mode* (2048x1536/low compression) up to 29 images Fine Mode (2048x1536) up to 57 images Normal/2x Digital Zoom Modes (1024x768) up to 145 images Burst Recording Mode (1024x768) up to 172 images 3x Digital Zoom Mode (640x480) up to 315 images Motion Image Recording Mode (12 sec. max./320x240) 19 sets TIFF Mode (2048x1536/no compression) 3 images
8/31/2005 1:38:48 PM • Panasonic iPalm... • Answered on Aug 31, 2005
I need charger for Panasonic ER2031K model beard hair trimmer
We do not sell anything here, try eBay.
11/22/2022 4:59:51 PM • Panasonic... • Answered on Nov 22, 2022
My Lumix dmc fz4 turns on and says memory card
Camera only supports Standard SD cards up to 2GB. I would go from there.
9/30/2022 12:11:49 AM • Panasonic... • Answered on Sep 30, 2022
I have a Panasonic Lumix DMC L580 and it states that the memory is full. As i dont have a manual how do i delete what is held in the memory please cheers
Are you sure of the model number? I can't find anything about a Lumix DMC-L580. There is a Lumix DMC-LS80. Make sure that you save any pictures before deleting them. Also make sure to have fresh batteries or the camera connected to AC power. If the camera runs out of power, the process will not complete. To delete pictures from the internal memory, slide the recording/playback switch down. (The switch to the upper left of the arrow keys on the back.) This puts the camera in Play Back Mode. Use the Up/Down arrows (if needed) to select normal playback mode and press Menu/Set (in the center of the arrow keys). The delete button is the one on the right side below the arrow keys. Use the left/right buttons to select a single picture. Press delete. Press the left arrow to highlight Yes. Then press Menu/Set to confirm deleting the image. To delete multiple pictures, use the down arrow to get to Multi Delete or All Delete (instead of the left arrow). Press Menu/Set. For All Delete, you may see an option to choose All Delete or All Delete except (star). The star indicates Favorites. If needed, pick one, press Menu/Set. Use the left arrow to select Yes and press Menu/Set again. For Multi delete, use the left and right arrows to navigate through the stored pictures. Press the down arrow to select an image to delete. When you have marked all of the pictures that you want to delete, press Delete again. Press the up arrow to select Yes and press Menu/Set to initiate deleting these pictures. (Note: if a picture is protected, pressing the down arrow will result in On icon blinking red.) The manual for DMC-LS80 is available from Panasonic support here: https://www.panasonic.com/au/support/manual-download/imaging/lumix-cameras/dmc-ls80.html . The current link to the manual is https://www.panasonic.com/content/dam/Panasonic/support_manual/Digital_Still_Camera/English_02-vqt3-vqt9_other/DMC-LS80%20Operating%20Instructions.pdf . See page 20 for the section on selecting the mode. See page 35 for deleting pictures. I hope this helps. Cindy Wells (if you have a memory card in the camera, you will need to do the delete steps in two steps. Delete all (or multi) pictures from the internal memory and the memory card separately.)
7/7/2022 6:22:48 PM • Panasonic... • Answered on Jul 07, 2022
3answers
MOVIE FILE NOT RUN
Your camcorder can only play back movies recorded on that specific device, due to the way the software within the camcorder works. PS - please don't shout when you post queries
3/14/2022 7:17:40 AM • Panasonic... • Answered on Mar 14, 2022
Panasonic iPalm PV-DC3010 Digital Camera Logo
9 questions posted
Top Panasonic Cameras Experts
Narseman
rhodesworks
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Panasonic Cameras
  • Panasonic Cameras
Most Popular Question
software
  • Cameras
