20 Most Recent Panasonic Lumix DMC-LS1 Digital Camera Questions & Answers
I have a Panasonic Lumix
Sounds like this isn't fixable by you...you will need to send it in for service. At least you've learned a valuable lesson...use the wrist strap.
8/31/2011 7:23:30 PM • Panasonic Lumix... • Answered on Aug 31, 2011
My Panasonic Lumix DMC-LS1
Does the power button are down into the camera and haven't turn up back?
4/25/2011 9:30:09 AM • Panasonic Lumix... • Answered on Apr 25, 2011
When i try to take
The hand symbol relates to the image stabilizer. Check your manual to choose a setting preference. As to zooming and not focussing, that could be a lens problem and you could try some of these solutions:
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
4/24/2011 2:03:56 AM • Panasonic Lumix... • Answered on Apr 24, 2011
2answers
I need driver for lumix dmc ls1
Please check on the following link for help:
Lumix
12/15/2010 11:28:58 AM • Panasonic Lumix... • Answered on Dec 15, 2010
Please turn off the camera and turn it on again.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/29/2010 11:50:28 AM • Panasonic Lumix... • Answered on Sep 29, 2010
My camera says my 'memory card is protected'.. how do I take this off?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
3/9/2010 6:22:44 AM • Panasonic Lumix... • Answered on Mar 09, 2010
Hi, i have a panasonic
You have to download quicktime player 7 as ur camera only plays .mov files. Download it from this link http://www.apple.com/quicktime/download/
1/10/2010 10:49:24 AM • Panasonic Lumix... • Answered on Jan 10, 2010
My camera will not upload pictures onto my
Buy an inexpensive card reader to download your pictures to a folder you create on your desktop.
10/14/2009 10:49:52 PM • Panasonic Lumix... • Answered on Oct 14, 2009
Screen says memory card is write protected
Hi there
Check to make sure the cards write protect is off, take the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Good luck and thanks for choosing FixYa!!
6/8/2009 5:58:28 PM • Panasonic Lumix... • Answered on Jun 08, 2009
Turn Off Flash
press on the button with the right arrow, next to the cammera's display. you will see that the flash icon on the screen now shows a circle with a bar across it
3/29/2009 1:40:52 PM • Panasonic Lumix... • Answered on Mar 29, 2009
Panasonic dmc-ls1
Hi there. You may need to change batteries. :)
12/17/2008 10:25:22 AM • Panasonic Lumix... • Answered on Dec 17, 2008
What do I do? It says... memory card is protected. I can't take photos or delete. :/
Some SD cards have a tiny "write protect" switch on the side. Might you have knowcked that? I would try taking the card out & seeing if you have one.
Otherwise, you can always look for the manual on the manufacturer's web site:
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-LS1
9/10/2008 8:58:30 PM • Panasonic Lumix... • Answered on Sep 10, 2008
Software for Lumix® Digital
No. These cameras store images in a JPEG format and can be used with any software package that can open a JPEG image.
8/31/2005 11:03:08 AM • Panasonic Lumix... • Answered on Aug 31, 2005
The camera's LCD screen goes black every so often
No. All Lumix® Digital Cameras have a built-in feature to conserve battery power. After a certain amount of inactivity, the LCD will power down to preserve the battery. Simply hit the SHTR button, and the LCD will turn ON.
8/31/2005 11:01:53 AM • Panasonic Lumix... • Answered on Aug 31, 2005
Lumix® digital camera storage path
Unlike 35mm cameras that store images on film, Lumix® Digital Cameras store images on SD Memory Cards, which make sharing and storing your pictures easy and convenient. You simply insert an SD Memory Card into the camera, take pictures until the card is full, and then you can transfer the pictures onto a compatible PC. Once you saved all your pictures, you can erase the card and start all over again.
8/31/2005 11:01:09 AM • Panasonic Lumix... • Answered on Aug 31, 2005
DPOF Print Mark Function
The DPOF Print Mark Function allows you to sort through the SD Memory Card and select the images you want to print by electronically marking them. You can then print the marked images on any DPOF compatible printer by hitting the AUTO PRINT button.
8/31/2005 11:00:33 AM • Panasonic Lumix... • Answered on Aug 31, 2005
Unlimited consecutive shooting function
This functionality allows unlimited consecutive shooting up to the capacity of the SD Memory Card in the camera—ideal for capturing fast-moving objects in high resolution. The number of shots may vary depending on memory card size, picture size, and compression.
8/31/2005 10:59:55 AM • Panasonic Lumix... • Answered on Aug 31, 2005
Effective megapixels
Effective megapixels are slightly less than the total number of pixels normally stated for an image sensor. They represent the actual number of pixels used to record an image.
8/31/2005 10:59:25 AM • Panasonic Lumix... • Answered on Aug 31, 2005
Panasonic Lumix DMC-LS1 Digital Camera Logo
24 questions posted
Top Panasonic Cameras Experts
ray gallant
Donald Gillies
Donald Gillies
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
screen says memory card write protected
  • Cameras
