20 Most Recent Panasonic Lumix DMC-LC70 Digital Camera Questions & Answers
There is no any option to change the language
Press the MENU button. Use cursor-left/right to select the wrench-and-screwdriver icon. Use cursor-up/down to select the last item on the menu (it looks like a letter "i" and a plus sign).
9/2/2012 2:51:50 AM • Panasonic Lumix... • Answered on Sep 02, 2012
When attempting to upload images
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
3/31/2011 6:38:43 PM • Panasonic Lumix... • Answered on Mar 31, 2011
2answers
No longer staying on
hey same thing happened to me today differnt type camera but, when it does it i shake the camera or tap it on a counter top and it fixes it
7/13/2010 2:27:04 PM • Panasonic Lumix... • Answered on Jul 13, 2010
How to transfer videos from Lumix DMC-LC70 to PC?
Easiest way...use a separate card reader to download to a folder you create on your desktop.
4/16/2010 9:34:18 PM • Panasonic Lumix... • Answered on Apr 16, 2010
I've accidentally switched my LC70 to Chinese -
Count the numbers you push the buttons.
2/23/2010 9:04:15 PM • Panasonic Lumix... • Answered on Feb 23, 2010
White lines
i read somewhere else that it is a shutter problem
10/10/2007 7:50:52 AM • Panasonic Lumix... • Answered on Oct 10, 2007
Memory Card Protected
On the memory card itself there is grey slider. Make sure it is NOT in the lock position.
1/26/2007 9:19:59 PM • Panasonic Lumix... • Answered on Jan 26, 2007
Download or view the user/ operation instructions
Put in the model number, check the "accept terms" box and click "locate manual".
9/6/2005 11:47:50 AM • Panasonic Lumix... • Answered on Sep 06, 2005
Software for Lumix® Digital
No. These cameras store images in a JPEG format and can be used with any software package that can open a JPEG image.
8/31/2005 10:52:38 AM • Panasonic Lumix... • Answered on Aug 31, 2005
The camera's LCD screen goes black every so often
No. All Lumix® Digital Cameras have a built-in feature to conserve battery power. After a certain amount of inactivity, the LCD will power down to preserve the battery. Simply hit the SHTR button, and the LCD will turn ON.
8/31/2005 10:52:03 AM • Panasonic Lumix... • Answered on Aug 31, 2005
Lumix® digital camera storage path
Unlike 35mm cameras that store images on film, Lumix® Digital Cameras store images on SD Memory Cards, which make sharing and storing your pictures easy and convenient. You simply insert an SD Memory Card into the camera, take pictures until the card is full, and then you can transfer the pictures onto a compatible PC. Once you saved all your pictures, you can erase the card and start all over again.
8/31/2005 10:51:27 AM • Panasonic Lumix... • Answered on Aug 31, 2005
DPOF Print Mark Function
The DPOF Print Mark Function allows you to sort through the SD Memory Card and select the images you want to print by electronically marking them. You can then print the marked images on any DPOF compatible printer by hitting the AUTO PRINT button.
8/31/2005 10:50:41 AM • Panasonic Lumix... • Answered on Aug 31, 2005
Unlimited consecutive shooting function
This functionality allows unlimited consecutive shooting up to the capacity of the SD Memory Card in the camera—ideal for capturing fast-moving objects in high resolution. The number of shots may vary depending on memory card size, picture size, and compression.
8/31/2005 10:50:10 AM • Panasonic Lumix... • Answered on Aug 31, 2005
Effective megapixels
Effective megapixels are slightly less than the total number of pixels normally stated for an image sensor. They represent the actual number of pixels used to record an image.
8/31/2005 10:49:29 AM • Panasonic Lumix... • Answered on Aug 31, 2005
MEGA Optical Image Stabilizer
The MEGA Optical Image Stabilizer helps correct hand movement from shaky hands, one of the main reasons why cameras produce blurry images. Lumix® Digital Cameras with MEGA Optical Image Stabilizer technology have a built-in gyrosensor that detects any hand movement and relays a signal to a tiny microcomputer inside the camera, which instantly calculates the compensation needed. A linear motor then shifts the Optical Image Stabilizer lens as necessary to guide incoming light from the image straight to the CCD. You won't even notice it working—all you'll see are the outstanding results!
8/31/2005 10:43:45 AM • Panasonic Lumix... • Answered on Aug 31, 2005
No battery power remains
On my Leica camera when I turn it on no battery power remains appears why is this?
11/23/2022 9:08:59 PM • Panasonic Lumix... • Answered on Nov 23, 2022
Sony camera service centre pakistan
if theres available online seller in your place try ordering online
4/15/2019 10:59:39 AM • Panasonic Lumix... • Answered on Apr 15, 2019
tip
If you have a older Lumix that does not want to power on
As you know Panasonic issues Firmware Updates that can be downloaded online, and then installed using a computer and an SD card. Some of those Firmware Updates made the cameras refuse to turn on if the battery was not an "approved" Panasonic battery. This significant change was not publicly announced. Panasonic Lumix batteries are available, but there are also dozens of different generic Lumix batteries available, and there is no reference source as to which generic batteries are "approved." Therefore I would encourage you if you have a Lumix camera that is balking on startup to first try a genuine Panasonic Lumix battery that is fully charged. You may find that the only problem was a generic battery that the camera did not care for. (And of course many "Lumix" batteries sold online are not actually Lumix batteries, but merely counterfeits. They have Lumix markings and are often very good imitations on visual inspection.) Another reason some Lumix cameras will not power up is the memory card. Sometimes people use a newer SDHC type card in an older Lumix, and the camera goes into electronic spasms trying to read the newer card. An older plain vanilla SD card will often solve the problem instantly. If a Lumix camera is not powering up with a 8gb SDHC card there is a good chance it will power up immediately with a 1gb SD card. I frequently recommend the Lumix TZ5 to people starting out, as it is a quality build, metal, not toy-like plastic, has more manual controls than most people will ever use, and the engineering is remarkable. I repair TZ cameras and donate them to homeless shelters and domestic abuse safe houses and college photography students and such, as they have full User Manuals available to download, full Service Manuals available for download in PDF format, have a very gentle learning curve, and produce photographs that are superior to many of the current cameras in the 600 to 800 dollar range. Yet a used TZ5 can be bought for 50 dollars or so. Update the Firmware to v 1.2, never carry it in a leather camera case or pocket or purse or with any cloth of any kind, and you have a superb camera for many years.
Panasonic Lumix DMC-LC70 Digital Camera Logo
19 questions posted
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
no longer staying
  • Cameras
