20 Most Recent Sony Cyber-Shot DSC-P41 Digital Camera Questions & Answers
If your computer is not recognizing this camera, then you may need some drivers to install on your computer. If any CD came with the camera, put that in your computer. If not, then go to this website and look for the drivers that match your operating system.
Sony Cyber-Shot... • Answered on Jul 20, 2015
Try formatting the stick and try again, sounds like it is corrupted.
Sony Cyber-Shot... • Answered on Jan 26, 2013
I own this camera and the same thing happened to me apart from the flash not working now the screen is upside down and flickering i dont know what happened.Im just gonna buy a new camera because this one take clear images as it is only 4 mp.
Sony Cyber-Shot... • Answered on Jun 14, 2011
p.41 of the manual has the instructions on how to delete images. Here is the link to the manual:
http://www.docs.sony.com/release/DSCP41.pdf
Thank you,
Lee
Sony Cyber-Shot... • Answered on Apr 08, 2011
i hope you didnt hit it with something the lense could have broken ... if you have warrenty claim it
i hope it helps u
Sony Cyber-Shot... • Answered on Mar 29, 2011
Press cursor-down on the multiselector (marked with a one-handed clock) to cycle through the different self-timer modes. Start the self-timer by pressing the shutter release button.
Sony Cyber-Shot... • Answered on Dec 17, 2010
Try to power it using battery and then, DC source. If its not powering, check battery contacts and clean them. If you have a volt measure unit, measure the volts from the DC source and compare the results with the values from the DC unit, also measure the battery and see its status. If you cant solve it in theis basic way, try to go to a professional repair center for a detailed analyzis. Cheers
Sony Cyber-Shot... • Answered on Dec 10, 2010
Hello Kyra
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Sony Cyber-Shot... • Answered on Nov 14, 2010
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Regards
Andrea
Sony Cyber-Shot... • Answered on Aug 11, 2010
Hi, thats probably the lens motor mechanism
who is dusty or sand or so inside where the
motor try to extand your lens block to move out
may be if you try to blow some air in the crack arround the base of the lens that could work
,if not you may need a good clean up in the mechanism..
goo luck ,hope that will help.
Sony Cyber-Shot... • Answered on Apr 12, 2010
I don't know preciselyfor this model but they don't usually.
Sony Cyber-Shot... • Answered on Jan 03, 2010
Hello
Ok, here is a link where you can download the manual for this device. Just click on the link below and click in get manual when you are at the site.
http://www.retrevo.com/s/Sony-DSC-P41-Digital-Cameras-review-manual/id/200bh926/t/1-2/
It states very clearly on how to turn on the flash. Hope this can help.
Kind regards
Andrea
Sony Cyber-Shot... • Answered on Dec 09, 2009
That't is normal, try lowering the your camera resolution and it would lower down the size. I just hope your are not yet on the lowest resolution.
Regards,
Jeep Brainy
Sony Cyber-Shot... • Answered on Sep 19, 2009
Why is your camera shaking? Go into the setup menu...maybe you can turn the vibration warning off.
Sony Cyber-Shot... • Answered on Aug 27, 2009
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000050574.pdf
Page 28
Sony Cyber-Shot... • Answered on Jul 08, 2009
First try sqeezing the camera very hard, if that doesn't work slam it as hard as you can in your hand. This usually solves the problem.
Sony Cyber-Shot... • Answered on Jun 10, 2009
It could be some grit or sand causing the lens cover to not open, so the camera won't initialize. Try cutting a slip of paper narrow enough to slide between the lens opening frame and the lens cover. Move it in and out to clear any grit that might cause the spring-loaded cover to bind. Good luck !
Sony Cyber-Shot... • Answered on Apr 13, 2009
This usually occurs when the camera is exposed to water, sweat, high humidity or if you had leaky alkaline batteries. You have 2 choices to try. 1 take the camera apart and use an old toothbrush with WD40 and scrub the circiut board, you can inspect the battery compartment to see if you have corrosion from leaky batteries and do the above to fix. 2 use the camera as is and remove the batteries after each use.
Sony Cyber-Shot... • Answered on Apr 05, 2009
Sony Cyber-Shot DSC-P41 Digital Camera Logo
41 questions posted
Top Sony Cameras Experts
Vish Iyer
Vish Iyer
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
turn flash sony cybershot
  • Cameras
