20 Most Recent
Mamiya 645 Pro TL Medium Format Camera Questions & Answers
It's been a while since I used a mamilla 645, so forgive me if this is wrong, but I seem to remember the dark slide would only come out with the camera wound on, ready to take a picture.
Mamiya 645 Pro...
Answered
on Dec 30, 2017
Probably not, but I would imagine you would need a lens
Mamiya 645 Pro...
Answered
on Dec 11, 2017
Test these instructions above, I hope it will work
Mamiya 645 Pro...
Answered
on Oct 30, 2014
we have 2 high end camera stores locally..creve couer camera and schillers on manchester in st louis..
Mamiya 645 Pro...
Answered
on Jan 13, 2014
It sounds like the aux. curtain that covers the film when you're focusing either is not properly lowering, or is damaged somehow. You can remove the back and look through to see if you notice any light coming through. If you do, consult a tech. You'd only notice it on frames because mid-frames wouldn't remain in the light path long enough to be affected under most circumstances. It'd likely be a tear/nick in the curtain. Or, it could just not be completely be closing.
It could also be an issue with bad seals in the film back, or between the back and body, or even a crack somewhere in the back or the body itself. If you can't find a leak in the curtain, try keeping the dark slide in right up til you take a shot in, taking it out as soon as you're ready to shoot, replacing it before you wind, etc. to minimize the amount of time light could come from the anywhere but the back - to try and narrow down the location of the leak.
Mamiya 645 Pro...
Answered
on Sep 04, 2011
First thing that comes to mind on this camera is that it's a modular camera. This means the film back can be changed mid roll so there is what is called a Dark Slide between the film back and the body.
The dark slide needs to be removed before the camera will function. Also depending on how "new" the film back is there may be a dark slide holder/sleeve on the back side of the film back.
So you remove the dark slide and slide is into the holder so first you don't loose it and also it doesn't get bent.
Diagram
Mamiya 645 Pro...
Answered
on Jan 09, 2011
hasselblad makes a digital back--approximately $20,000 USD (yes, that is 20 THOUSAND) and then you need the adaptor (approx. another $1000-$1500 USD). If you can afford that, why not buy a NEW MAMIYA RZ22 (22 mP) or the 33 (33 MP)? would cost less and already digital.
Mamiya 645 Pro...
Answered
on Dec 04, 2010
After loading the back with film, the dark slide is inserted so you may remove the back without ecxposing the film. Suppose you had 2 different back, 1 with b&w and the other has color. You are shooting with color. Load the color film and before shooting, remove the dark slide. After a few shots, you decide to change to B&W, insert the dark slide, change backs, remove that dark slide and continue shooting. This is assuming that you have 2 dark slides, 1 for each back. If you only have 1 dark slide, then the back that is not on the camera needs it if it is loaded with film and the other back will have to stay on the camera.
Mamiya 645 Pro...
Answered
on Nov 01, 2010
This is copyright material and has never been made publicly available, but you can buy copies from John Craig of Craig Camera in Torrington, CT, USA. He provides an excellent service but if you have any concerns regarding legality then you'll have to check with him if you're concerned as to whether he has the rights to re-publish original copyright works.
Scroll down to items #90050 and #90502 on his
website.
If you're looking for this information for free then you'll have to search further than I've just done: not everything is free on the net.
Mamiya 645 Pro...
Answered
on Mar 05, 2010
