20 Most Recent Sony Cyber-Shot DSC-V3 Digital Camera Questions & Answers
The manual on page 122 says: Vertical streaks appear when you are shooting a very bright subject. Cause / Solution : The smear phenomenon is occurring. This phenomenon is not a malfunction. So when you are photographing in bad light, and some where in the frame is a bright light, from that light, white vertical strips can occur. But you mention Horizontal lines. If this happens in normal light, outside, or in every light condition, something else must be wrong. I wonder if bringing a 10 year old camera to a repair store or Sony service centre is worth doing.
Sony Cyber-Shot... • Answered on Jan 29, 2014
This from Sony website:
To ensure the proper operation of the battery, please do as follows after charging the battery.
(1) When charging by connecting the AC adaptor directly to the camera Pleasedisconnect DC IN from the camera after charging is completed. Also, itis recommended to remove the battery from the camera when charging iscompleted as the battery is discharged slightly even if the camera isturned off.
(2) When charging with the supplied USB cradle Ifthe camera is installed in the USB cradle, please leave the power cordconnected to the outlet (when using the power strip, please leave itsswitch to on).If you want to unplug the power cord (or switch off thepower strip) after the battery has been charged using the USB cradle,please remove the camera from the USB cradle. Also, it is recommendedto remove the battery from the camera when charging is completed as thebattery is discharged slightly even if the camera is turned off.
NOTE: When you charge the battery by connecting the AC adaptor directly tothe camera or using the USB cradle, do not leave it with the power corddisconnected from the outlet.
Should it not work, continue with the manual reset procedure below:
  1. Turn off the camera.
  2. Ensure the camera is not connected to an AC power adapter.
  3. Remove the battery from the camera for 15 seconds.
  4. Reinsert the battery.
  5. Turn on the camera.
NOTE: If the issue is not resolved by performing a reset procedure, service may be required .
Sony Cyber-Shot... • Answered on Mar 12, 2013
see the diagram attached and use the common sense.God bless you. see the video and use the common sense.9_23_2012_12_11_54_pm.jpg
Sony Cyber-Shot... • Answered on Sep 23, 2012
Is it Sony DSC-V3 camera that you are looking for shutter button info?
Sony Cyber-Shot... • Answered on Aug 23, 2012
The camera thinks you have an external flash attached.
Sony Cyber-Shot... • Answered on Aug 22, 2012
You're going to have to take the camera into a camera shop to have the lens cleaned. There are special tools and other items that you need to have to take the lens apart and put it back together. I would phone around to different camera stores in your area to see what they would charge you to do the cleaning as it will probably vary quite a bit from shop to shop.
Sony Cyber-Shot... • Answered on Jun 29, 2011
Before you take a picture, change video mode to picture mode, you can change from MENU setting.
If you already have videos and you want to save picture from them, you can play the video, then pause where you want to save the picture. Click PrtSc on your keyboard (Print Screen) > Save the picture > Edit with Adobe Photoshop > Direct Print or you can insert in Office Word page before print them. Some media player even support screen captor, like Power DVD. You can save pictures easily with this software !
Hope this help and if you feel helped, RATE please !
Sony Cyber-Shot... • Answered on Jan 20, 2011
i think this is a faul of the power button. if the power button remains pushed the camera turns on alone. of the power button. i dont know your specific caera. but its possible to find a faulty camera on ebay but the camera does not have your same problem. you can pull out the power circuit and substitute with your. the care circuit are some a puzzle alle pieces are distintly power circuit lens circuit motherboard flash circuit. open faultu camera that you buy so you can see exactly how you nust do to disassemble the circuit, and later instal the circuit on your camera. its important to protect the circuit from static eletricity. and it s important that you pull out the batterie befor to disassemble.
sorry for my bad english
Sony Cyber-Shot... • Answered on Aug 05, 2010
Sounds like a short. Is the battery in correctly? Is there anything laying across the contacts in the battery compartment?
Sony Cyber-Shot... • Answered on Jan 12, 2010
http://www.fixya.com/support/r3771170-phone_water_damage
As for the sand, I'm not sure how that would be removed.
Sony Cyber-Shot... • Answered on Jan 08, 2010
You download the file just like you download your pictures. As long as you have a player on your computer capable of playing it back, all you have to do is double-click on the image.
Sony Cyber-Shot... • Answered on Sep 15, 2009
I can solve these issues in about 2 minutes. email me @[email protected]
Sony Cyber-Shot... • Answered on Dec 16, 2008
Have you checked the batteries to make sure they are still viable?
Sony Cyber-Shot... • Answered on Oct 11, 2008
The mode dial button seems to be overused. You can easily open your camera (I did with a philips driver), but I don't think you can do something without soldering iron.
Sony Cyber-Shot... • Answered on Jun 13, 2008
The camera body has a tiny switch marked "CF" in one position and Sony's "memory stick" symbol in the other. Apparently I accidentally reset the switch from "memory stick" to "CF" while slipping the camera body into (or out of) its carrying-case. Once I had set this switch from "CF" back to the "memory stick" position, everything worked fine. Solution:  read the user's manual more carefully next time!!
Sony Cyber-Shot... • Answered on May 09, 2008
Sony Cyber-Shot DSC-V3 Digital Camera Logo
26 questions posted
Top Sony Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Harrie
NOEL
NOEL
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
disassembly instructions sony dsc v3
  • Cameras
