20 Most Recent Sony PSYC ZS-D55 Cassette/CD Boombox Questions & Answers
One possibility is that there is a scratch on the CD lens. But first try cleaning again, but this time use Isopropyl Alcohol. As meths might leave residue behind.
Sony PSYC ZS-D55... • Answered on May 06, 2017
Some displays have one or too bulbs that are solded to the board to highlight the digital display usually hidden behind the screen, this is a very difficult repair because it requires a complete dis-assembly to get at the parts, but if the display is completely dead there is no voltage reaching the display ic.
Sony PSYC ZS-D55... • Answered on Jul 11, 2012
You may download the manual for yourself here.
Sony PSYC ZS-D55... • Answered on May 04, 2012
HelloCheck the metal battery contacts at the set for any rust or dirt accumulated on springs of pads, restricting the flow of current from backup batteries to the inside circuit of the set. Backup batteries should be replaced after 12 months periodically to retain data. When you replace the battery, the data stored will be lost, and you have to re-enter all the data once again. OK.
Sony PSYC ZS-D55... • Answered on Nov 20, 2011
Hello
All the Sony components are avialble with Sony Authorised Service center. You can contact them for the replacemant part. If you want to buy it from an other source try with "Alibaba"; "Ebay" "AB components" [Songapore] etc. They will have the exact component of your need, give them the model number and part which you want to muy from them. Can be bought by E-Payment. They will reach tghe compnent at your doorstep.
If you want any manual of your device, ie, user manaul or service manual; send your email address to me by FixYa comment box. I've both of them and will send a copy of it to you by return mail.OK.
Sony PSYC ZS-D55... • Answered on Jul 22, 2011
You will have to order the part from sony service center.This round part which holds the cd in tray is not available in spare by other sites.But you might get at sony service center parts store. Click this link below:--- http://esupport.sony.com/US/perl/model-accessories.pl?XID=M:sidenav:esupport ----------- For more help click this sony service center link:---
http://esupport.sony.com/US/perl/model-accessories.pl?XID=M:sidenav:esupport ------------ Also the broken, part.If its in good condition, or just broken in two pieces, you can try sticking it by proper glue or fevi-stick and see.If it gets tight.But once you stick the broken part with glue, you will have to let in remain for few hours without moving it.Then only it will get/ hold of good grip and become stiff to hold the cd.---------Check out.this should help.Thanks.Helpmech.,
Sony PSYC ZS-D55... • Answered on Apr 17, 2011
Hi I'm not familiar with your particular model, but the auto stop problem is common and is usually the result of a slipping drive belt, or bad idler/reel drive. The auto-stop works by popping a small tooth like plastic or nylon piece attached to an arm, when you runout of tape and takeup reel pulls the tape tight. The auto-stop mech can get contaminated with dust, and not work, or the reel for some reason does not pull the tape tight enough to fully engage that piece and the result is a ticking sound. As the deck now has your tape, I suspect the main drive belt is broken or probably slipping, and all will work fine if it is replaced. Although changing the belt is not difficult, you should probably take it to a repair shop, as getting the right size is important, and the deck may have to be dismantled to change it. Hope this helps, good luck!
Sony PSYC ZS-D55... • Answered on Dec 28, 2007
Unlikely as Sony like to do their things their way!
Sony MHC-GX450, MHC-RG444S, SS-WG450 Service ...
https://servlib.com > Sony > Audio
SERVICE MANUAL MHC-GX450 / MHC-RG444S / SS-WG450.pdf DOWNLOAD Size 39.41 KB Sony ' Audio.
Need help with a Sub woofer. : hometheater - Reddit
https://www.reddit.com > hometheater > comments > ne...
Sep. 2, 2015 - I have an old Sony SS-WG450 sub woofer and want to connect it to a Denon AVR S700w reciever. It only has an audio cable and what appears to be a ... just got a new receiver and I'm wondering how to hook my old ... Dec. 31, 2015 Finding the right amplifier for my Sony Speakers. : audio - Reddit Jan. 8, 2017 More results from www.reddit.com
Sony Ss-wg450 150w 8" Active Subwoofer Speaker ...
https://www.ebay.com > ...
Find many great new & used options and get the best deals for Sony Ss-wg450 150w 8" Active Subwoofer Speaker Only at the best online prices at eBay! US$130.00 · ‎In stock
SONY SS-WG450 Service Manual - download free - NoDevice
https://www.nodevice.com > ... > SONY > SS-WG450
SONY SS-WG450 Service Manual PDF file download free. SONY SS-WG450 Service Manual will help to repair the device and fix errors.
Sony Audio... • Answered on Apr 02, 2021
The loading process is out of sync, most likely because of a stretched belt in the mechanism. This is a common problem with Sony "jukeboxes".
Sony Audio... • Answered on Mar 15, 2021
what need to do is go into the settings menu and find the section on sorting it out or you could do a factory reset. That should get you sorted..
Sony Audio... • Answered on Mar 08, 2021
possible blown outputs
Sony Audio... • Answered on Feb 28, 2021
Sony PSYC ZS-D55 Cassette/CD Boombox Logo
18 questions posted
Top Sony Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
seeking owner 39 s manual
  • Audio Players & Recorders
