20 Most Recent
AudioSource Amp Two 2-Channel Amplifier Questions & Answers
Audiosource amp two intermittent distortion in monoblock mode
Good question, well constructed, a real fault report.
I would say from you fault description that maybe there is a dry joint / loose connection somewhere in the system.
So check all your wiring / connections.
Put the amp back into 2 ch mode and check each ch with the same source and load, do it both cold, and then drive the amp and do it hot do the shake test on both ch, cold and hot.
maybe this will help id the faulty area, if both ch have fault the it might be the psu as this is common to both sides.
If you can track down the fault to a or b then you can resolder all the connections on the board, if you are not happy with taking the lid off then take your amp with your test report to a tech, the test results may save you time and money.
Hope this helps, thanks for using FixYa.
? connecting AudioSouce amp two to my receiver
if you're using the receiver as a preamp, you'll need a low level output on the receiver which tracks with the volume control on the receiver. Some receivers have "preamp out" jacks which are tracked with the volume control on your receiver. This is what you're supposed to use. However, if you don't have this feature, you can use the headphone jack on your receiver. This is what I do with my amp and it works great!
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
