20 Most Recent Inland ProHT Bluetooth Headset Pink Questions & Answers
All you have to do is turn then off and when you're going to turn them back on keep pressing the power button until you hear bluetooth linking, it won't ask for a pin after that.
Radio... | Answered on Oct 11, 2020
there are others with similar issues on fiat 500 radios. seems others are related to having usb devices connected and playing. so maybe its issue with player. or maybe if you have a usb cable connected, try removing it, or even try plugging in a usb stick with some music on it and see if that frees it up. i do know its interconnected with things like phones that can interrupt and PUT ON HOLD the radio so maybe its phone related so there are other inputs at the back i expect which could be grounded if you arent using them maybe...
Radio... | Answered on Oct 10, 2020
Measuring across the commutator opposites is a rough check - if each pair has the same resistance it is probably good but even then there are no guarantees. I have never seen the armature resistance stated for any motor though that doesn't mean such figures don't exist.
It would seem logical that each pair should be isolated but that generally is not how the armature is wired and each commutator segment is the termination of two coils.
In reality there is only three ways to test an armature - either build it into a motor and see if it performs ok, use an automated motor fault analysis machine or one of the dedicated armature testers such as an armature growler.
Radio... | Answered on Aug 01, 2020
Several things come to mind:
* check the batteries in the headsets, are they good?
* check that the transmitter is powered up and connected to the audio circuit in the TV.
Radio... | Answered on Jul 16, 2020
The fashion for nostalgia radio with a modern sound has brought about a clutch of models from only a few manufacturers.
I have only encountered one such that was basically an in-house cabinet with bought in internals, the quality of which was probably reflected in the price and as this was from the lower price bracket the internals were from different sources and badly matched.
I know of no reason to assume other models would be substantially different because although popular they haven't sold in the high numbers that would justify purpose built internals and so the chances are an experienced audio engineer would probably recognise the circuit board as being from a popular hi-fi and be able to provide you with details.
Radio... | Answered on Jun 22, 2020
There are two versions. A free version and a paid version. Make sure you choose the free one and you will not be charged anything. You may need to uninstall the one you have downloaded and reinstall. Do not choose PREMIUM vesion.
Radio... | Answered on Jun 17, 2020
The short answer is no -- the difference between AM and FM is too great though some CB radios were made dual mode, like the President Veep I used to own.
Some CBs that found the way into Britain were powerful sidebanders that offered similar capabilities to unlicensed CB-ers to that official radio hams had to sit exams to enjoy. Some radio hams found it cheaper to have those top-line CBs modified for use on the 11 metre amateur band.
It would be no help to you to obtain a standard FM CB as when the UK was forced to legalise CB radio under the Treaty of Rome, they legalised it at a different frequency as the American frequency was already allocated to radio control, bleepers and other things. Special CB sets were manufactured for the UK market.
Radio... | Answered on Jun 15, 2020
HI.... yes ....it is possible to program them in DMO, this is done in the RSS,.... so I am advised directly from inside Motorola .... but a copy of the RSS is just not available.... ... if fact Motorola seems to officially deny the D700 ever existed ... good luck in finding a solution.
Radio... | Answered on Jun 12, 2020
Hello there! Assuming your talking about "XtremeMan SOMA BT" I'm not a fan of assumptions but... if this is the device your are referring to then here you go below. If this is not the device you are making reference to, then please respond with the model number and make/brand of the device. Thanks for your visit and good luck.
1. With the unit on or off, plug the included cable
from the USB jack on your computer to the micro
USB jack v on this unit. While charging, the
battery level will be shown by the LED indicators
with the current level LED blinking. When all
the LED indicators light solid, then the unit
is fully charged.
2. If the power level is less than 10%, the left-most
LED indicator will start blinking, which means
that the Soma BT needs to be charged.
Using the Soma BT with a Bluetooth Device
1. Turn on the unit as shown above.
2. Press and hold the Bluetooth button U for
approximately three seconds until a beep
sounds and the right-most LED starts blinking.
3. Within five minutes, select Soma BT from the
Bluetooth List on the external device. See
external device's owner's manual for details.
When paired successfully, the Soma BT will beep
twice and the right-most LED will light
https://www.manualslib.com/manual/1540329/Xtrememac-Soma-Bt.html?page=8#manual Check Here
Radio... | Answered on May 20, 2020
The meter is out of range! Move the meter closer to the main box.
Radio... | Answered on May 17, 2020
cut bluetooth on phone.. unplug alexa and tell her to turn of blue tooth on devices.
Radio... | Answered on May 06, 2020
Inland ProHT Bluetooth Headset Pink Logo
0 questions posted
Top Inland Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you an Inland Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Inland Radio Communications
Most Popular Question
will not pair ipad 2
  • Radio Communications
