20 Most Recent
Dynex - USB Stereo Headset DX-850 Questions & Answers
Not installing in my Macbook
Plug the USB connector into an available externalUSB port on your computer or laptop. On mostcomputers, drivers install automatically and yourheadset will be ready to use.
The sound is distant?
Plug the USB connector into an available USB port.• Check your computer's volume level.• Check if your computer's volume is muted.• Check your operating system's audio input and output settings.• Check the headset's volume and mute settings.• Restart computer.
When I try to use
What is the model of your Dynex Headset? Please try to plug it into another USB port. Also, as part of the troubleshooting, try to use it into another computer. If it works, please take note of the operating system version.
Try to download also the driver from the manufacturer's website. Make sure though that you select the correct operating system to avoid conflicts.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
