20 Most Recent
Emerson PD6870RD Radio/Cassette/CD Boombox Questions & Answers
Pause button is stuck
hi soblessed,
the plastic push lock that holds the button is possibly broken, but hopefully the mechanism incorporated with the button has not been damaged because it was pushed too far.
to have this issue resolved, you may use something pointed to nudge the button from its place and free it from being stuck. Or you may remove the screws from the button, freeing the upper case from the lower case exposing the other side of the controls, so you can push the pause button out.
regards,
voodoo
Emerson HT-200B Digitial Stereo Amplifier no sound
Try to establish if it has power going to it. If not you are looking at the power supply. If it has power then you are looking the audio output. If you take off the top and see a device like in the picture then you can bet that has failed.
How to adjust buzzer volume on an Emerson smartset alarm clock, CKS1521?
Please check the bottom and back of your alarm clock for the buzzer volume option. If you can't find it, please refer to your manual. If this is not in the manual, then it might no be built into your product and you might need to trade-in for a new alarm clock that allows you to adjust the buzzer volume. Thank you.
