20 Most Recent Nortel Norstar M7310 Display Phone Questions & Answers
The greeting is from the voice mail not your phone.
Logging In To a Mailbox From Your Own Extension
1 - Feature 981
2 - Pswd: Dial 4-digit password (default is 0000)
Follow prompts to change your greeting. They are: ADMIN, then GREET and then RECORD.
When done hang up or push RLS. I have installed several of these systems.
Nortel Norstar... | Answered on Mar 08, 2018
If you set the all line and set restrictions to no restrictions, you are not restricted from making any calls. I don't think it's the phone system requiring this 4 digit code. Are you sure all your lines are set with the same long distance provider. Did the lines in the dial 8 group require a code. (ie some users had the long distance provider set up their lines to need a code entered to charge calls off to different job codes, so they can distribute the charges correctly).
You should now be able to call 9+1+area code+number, with no restrictions.
Nortel Norstar... | Answered on Apr 13, 2014
Answer> Manuals: If you want FREE manuals for your device, you must go directly to the maker of your hardware device. Look for their SUPPORT (Drivers and Downloads) and input the required data such as the Make, Mod. of the device in question. They will then take you to the proper section where Drivers and Manuals are located. Here you simply select the option you want to download and install your drivers or open a manual. Manuals often come down in PDF format and require Adobe Reader. Get Reader form http://www.Adobe.com .
Nortel Radio... | Answered on Dec 24, 2013
Hello there! Assuming your talking about "XtremeMan SOMA BT" I'm not a fan of assumptions but... if this is the device your are referring to then here you go below. If this is not the device you are making reference to, then please respond with the model number and make/brand of the device. Thanks for your visit and good luck.
1. With the unit on or off, plug the included cable
from the USB jack on your computer to the micro
USB jack v on this unit. While charging, the
battery level will be shown by the LED indicators
with the current level LED blinking. When all
the LED indicators light solid, then the unit
is fully charged.
2. If the power level is less than 10%, the left-most
LED indicator will start blinking, which means
that the Soma BT needs to be charged.
Using the Soma BT with a Bluetooth Device
1. Turn on the unit as shown above.
2. Press and hold the Bluetooth button U for
approximately three seconds until a beep
sounds and the right-most LED starts blinking.
3. Within five minutes, select Soma BT from the
Bluetooth List on the external device. See
external device's owner's manual for details.
When paired successfully, the Soma BT will beep
twice and the right-most LED will light
https://www.manualslib.com/manual/1540329/Xtrememac-Soma-Bt.html?page=8#manual Check Here
Radio... | Answered on May 20, 2020
The meter is out of range! Move the meter closer to the main box.
Radio... | Answered on May 17, 2020
cut bluetooth on phone.. unplug alexa and tell her to turn of blue tooth on devices.
Radio... | Answered on May 06, 2020
T squelch and PTT on can be reset by button presses. It's shown in the manual, available for free online in various places.
Radio... | Answered on May 04, 2020
EMAILING THINGS IS NOT WHAT WE DO . IF WE ASSIST YOU WILL GET NOTIFICATION ON THE WEBSITE A BELL SYMBOL WITH A NUMBER ON IT AT TOP RIGHT CORNER .
Radio... | Answered on Apr 22, 2020
All you have to do is turn then off and when you're going to turn them back on keep pressing the power button until you hear bluetooth linking, it won't ask for a pin after that.
Radio... | Answered on Apr 21, 2020
  • There is no need to send the radio to some unsanctioned moonlighter.
  • I normally don't recommend clipping parts but for this radio there is not much else to do and it looks OK on an Oscilloscope too. Clip diode 205 to increase modulation. Then take a plastic flat tool and spread L 203 coils apart about a 1/8" each, nice and even and make sure they don't touch any metal.
  • Hope this helps.
Radio... | Answered on Apr 13, 2020
BC200XLT - The RadioReference Wiki
wiki.radioreference.com > index.php > BC200XLT
Aug 23, 2019 - Released circa 1988, the BC200XLT, along with little brother BC100XLT, ... Covered 29-54, 108-174, 406-512, 806-956 MHz; Manual Channel ...
UNIDEN BC200XLT USER MANUAL Pdf Download.
www.manualslib.com > ... > Uniden Manuals > Scanner > BC200XLT
View and Download Uniden BC200XLT user manual online. 200-Channel Programmable hand-held scanner. BC200XLT Scanner pdf manual download.
UNIDEN BC200XLT SERVICE INFORMATION MANUAL Pdf ...
Uniden BC200XLT User Manual 28 pages. Scanner Uniden BC 248CLT Reference Manual. ... Scanner Uniden BC246T Owner's Manual.
Radio... | Answered on Apr 08, 2020
It says 'No Link' on your mystery object.
Recreate the link.
Radio... | Answered on Apr 04, 2020
Unfortunately these mics are not professional quality and they tend to be less accurate.
The variable selectors have a wide tolerance and are not precise, thus; they tend to be hard to control.
Not much you can do...so use it as is, or get a new unit.
Radio... | Answered on Apr 02, 2020
Nortel Norstar M7310 Display Phone Logo
12 questions posted
Top Nortel Radio Communications Experts
Harrie
MrFixitSTTL
ray gallant
Are you a Nortel Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Nortel Radio Communications
Most Popular Question
norstar m7310 cannot get greeting from
  • Radio Communications
