20 Most Recent Nortel Networks T7208 Telephone Questions & Answers
I managed to find the manual, but it does not say a thing about this. I think your provider has to give you the information, with the incoming call. When he switched that information of, your phone can't display it. Sometimes the providers charge you extra for that service. If, on the same extension, another phone did display the number, perhaps hetre is a way to switch it on, but I could not find it.
The link is to the manual.
http://ipf.msu.edu/_files/pdfs/user-guides/norstar-t7208.pdf
Nortel Networks... | Answered on Oct 06, 2015
Answer> Manuals: If you want FREE manuals for your device, you must go directly to the maker of your hardware device. Look for their SUPPORT (Drivers and Downloads) and input the required data such as the Make, Mod. of the device in question. They will then take you to the proper section where Drivers and Manuals are located. Here you simply select the option you want to download and install your drivers or open a manual. Manuals often come down in PDF format and require Adobe Reader. Get Reader form http://www.Adobe.com .
Nortel Radio... | Answered on Dec 24, 2013
The fashion for nostalgia radio with a modern sound has brought about a clutch of models from only a few manufacturers.
I have only encountered one such that was basically an in-house cabinet with bought in internals, the quality of which was probably reflected in the price and as this was from the lower price bracket the internals were from different sources and badly matched.
I know of no reason to assume other models would be substantially different because although popular they haven't sold in the high numbers that would justify purpose built internals and so the chances are an experienced audio engineer would probably recognise the circuit board as being from a popular hi-fi and be able to provide you with details.
Radio... | Answered on Jun 22, 2020
There are two versions. A free version and a paid version. Make sure you choose the free one and you will not be charged anything. You may need to uninstall the one you have downloaded and reinstall. Do not choose PREMIUM vesion.
Radio... | Answered on Jun 17, 2020
The short answer is no -- the difference between AM and FM is too great though some CB radios were made dual mode, like the President Veep I used to own.
Some CBs that found the way into Britain were powerful sidebanders that offered similar capabilities to unlicensed CB-ers to that official radio hams had to sit exams to enjoy. Some radio hams found it cheaper to have those top-line CBs modified for use on the 11 metre amateur band.
It would be no help to you to obtain a standard FM CB as when the UK was forced to legalise CB radio under the Treaty of Rome, they legalised it at a different frequency as the American frequency was already allocated to radio control, bleepers and other things. Special CB sets were manufactured for the UK market.
Radio... | Answered on Jun 15, 2020
HI.... yes ....it is possible to program them in DMO, this is done in the RSS,.... so I am advised directly from inside Motorola .... but a copy of the RSS is just not available.... ... if fact Motorola seems to officially deny the D700 ever existed ... good luck in finding a solution.
Radio... | Answered on Jun 12, 2020
It'll be them Duke boys again!
Radio... | Answered on Jun 07, 2020
Never heard of that before, but the Internet has.
https://www.google.com/search?q=remote+to+my+wingman
Radio... | Answered on Jun 03, 2020
Hello there! Assuming your talking about "XtremeMan SOMA BT" I'm not a fan of assumptions but... if this is the device your are referring to then here you go below. If this is not the device you are making reference to, then please respond with the model number and make/brand of the device. Thanks for your visit and good luck.
1. With the unit on or off, plug the included cable
from the USB jack on your computer to the micro
USB jack v on this unit. While charging, the
battery level will be shown by the LED indicators
with the current level LED blinking. When all
the LED indicators light solid, then the unit
is fully charged.
2. If the power level is less than 10%, the left-most
LED indicator will start blinking, which means
that the Soma BT needs to be charged.
Using the Soma BT with a Bluetooth Device
1. Turn on the unit as shown above.
2. Press and hold the Bluetooth button U for
approximately three seconds until a beep
sounds and the right-most LED starts blinking.
3. Within five minutes, select Soma BT from the
Bluetooth List on the external device. See
external device's owner's manual for details.
When paired successfully, the Soma BT will beep
twice and the right-most LED will light
https://www.manualslib.com/manual/1540329/Xtrememac-Soma-Bt.html?page=8#manual Check Here
Radio... | Answered on May 20, 2020
The meter is out of range! Move the meter closer to the main box.
Radio... | Answered on May 17, 2020
cut bluetooth on phone.. unplug alexa and tell her to turn of blue tooth on devices.
Radio... | Answered on May 06, 2020
T squelch and PTT on can be reset by button presses. It's shown in the manual, available for free online in various places.
Radio... | Answered on May 04, 2020
EMAILING THINGS IS NOT WHAT WE DO . IF WE ASSIST YOU WILL GET NOTIFICATION ON THE WEBSITE A BELL SYMBOL WITH A NUMBER ON IT AT TOP RIGHT CORNER .
Radio... | Answered on Apr 22, 2020
All you have to do is turn then off and when you're going to turn them back on keep pressing the power button until you hear bluetooth linking, it won't ask for a pin after that.
Radio... | Answered on Apr 21, 2020
  • There is no need to send the radio to some unsanctioned moonlighter.
  • I normally don't recommend clipping parts but for this radio there is not much else to do and it looks OK on an Oscilloscope too. Clip diode 205 to increase modulation. Then take a plastic flat tool and spread L 203 coils apart about a 1/8" each, nice and even and make sure they don't touch any metal.
  • Hope this helps.
Radio... | Answered on Apr 13, 2020
Nortel Networks T7208 Telephone Logo
1 questions posted
Top Nortel Radio Communications Experts
Harrie
MrFixitSTTL
ray gallant
Are you a Nortel Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Nortel Radio Communications
Most Popular Question
program t7208 telephone display incoming
  • Radio Communications
