20 Most Recent JVC KA-310U Questions & Answers
My JVC Ha-s20bt doesn't want to pair with my device..
1. Check that the power is turned off power lamp off s20_dntxilxgecvgvp-undefined-undefined-0.png 2. erform one of the following operations depending on the connection status. When connecting for the first time Hold down button for 3 seconds until the indicator flashes alternately in red and blue. When there are 2 or more the BLUETOOTH devices to connect to Hold down button for 5 seconds until the indicator flashes alternately in red and blue. connecting_s20bt_jeawiluqvwxlgs-undefined-undefined-1.gif 3. Turn on the Bluetooth function of the BLUETOOTH device. connecting 2 new_dntxiljgmiiddj-undefined-undefined-3.png 4. Select "JVC HA-S20BT" from the device list. connecting 3 s20bt_dntxilmycugtzm-undefined-undefined-10.png 5. The indicator flashes slowly in blue when a connection is completed. blue_flash_s20bt_jeawilhopkechq-undefined-undefined-15.gif Please note : During the pairing process, the BLUETOOTH device may require input of a PIN code. In such a case, enter "0000" as the PIN code for the System. If connection (pairing) is not completed within 5 minutes after the indicator starts flashing, the System automatically turns itself off.
9/30/2021 4:49:32 PM • JVC Radio... • Answered on Sep 30, 2021
JVC Bluetooth headset red light keeps blinking what does that mean
Generally, the flashing red light means that the device needs to be charged.
9/24/2019 2:55:39 PM • JVC Radio... • Answered on Sep 24, 2019
Mic in my new JVC radio isnt working on bluetooth. I can hear them but they can’t hear me. Please help.
For the people who answered above, what the hell does Windows Visa has to do with a car radio?
3/12/2019 12:49:34 PM • JVC Radio... • Answered on Mar 12, 2019
Unlock an nokia 6303 mobile
Try this please : This worked with many people with same phone .
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to switch on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
good luck .
please rate !
10/5/2010 4:48:06 AM • JVC Radio... • Answered on Oct 05, 2010
2answers
I need to know which is the signal wire to the maf
In a three wire MAF sensor, one terminal will be the negative wire, the next terminal will be the signal wire, and the last terminal will be the current wire, the way to know which terminal is the signal, is to connect the negative terminal of your voltmeter to a good ground in your vehicle, next make sure that there are not any wires that may get tangled in the fan or belt of the car and start the engine. probe the terminals in the MAF sensor, the ground terminal will show nothing , one of the remaining two will have constant 5 volts, and the signal wire will vary its current depending on the engine speed, between 0.6 volts at idle to around 4.5 volts at wide open throttle.
Once you have the positive prove of your voltmeter its the signal wire.
7/10/2009 4:02:55 PM • JVC Radio... • Answered on Jul 10, 2009
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
  1. Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
  2. Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
  3. Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
  4. Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM • Radio... • Answered 18 hours ago
2answers
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM • Radio... • Answered on Apr 04, 2024
The LED light display is not working on the face of detachable headset is there some button i can press to enable Firetail FT-8238D
I have the same problem. When o remove the interface the led is not flashing as per the instruction manual
3/27/2024 5:24:11 AM • Radio... • Answered on Mar 27, 2024
I need a manual for a TRONIC PLL 2023 radio. Can you help? Ray
http://www.manuals.group/results.php?search=TRONIC%20PLL%202023%20KURZ
3/26/2024 7:06:10 AM • Radio... • Answered on Mar 26, 2024
I have a Sonoff switch device which worked fine until I changed Broadband. Now the eWeLink cannot pair to the device??
Home - SONOFF OfficialSONOFF Official https://sonoff.tech Explore the innovative world of SONOFF, learn and chose about various smart home products, define your smart home,your smart choice!‎SONOFF Products · ‎Basicr2 · ‎ZigBee Bridge · ‎Home AUTOMATIONA Thorough Pairing Guide To SONOFF Smart Devices And ...SONOFF Official https://sonoff.tech > product-review > tutorial > how-to-p... How to quickly pair sonoff smart devices with ewelink app? This guide covers a complete and instuitive pairing instruction for all sonoff devices.Contact maker support. It is likely an issue with the new broadband router. The will know if there are compatibility issues..
3/24/2024 6:49:12 PM • Radio... • Answered on Mar 24, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please. Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity. https://www.google.com/search?q=KPG-790 ..
2/15/2024 3:06:45 AM • Radio... • Answered on Feb 15, 2024
Motorola KEM-P29923 2 Way Radio. It can transmit but cannot receive messages.
There are some ideas here, but also make sure Squelch isn't all the way up, that you aren't on some type of mute and that the Volume isn't at Zero. https://www.google.com/search?q=two-way+radio+transmits+but+does+not+receive https://www.google.com/search?q=KEM+P29923 ..
2/9/2024 1:12:05 AM • Radio... • Answered on Feb 09, 2024
New Motorola Mag One radio fully charged will transmit but will not receive. why?
This question edited for clarity. Contents of correction Question added here and Deleted. Did you read the Manual? It looks like it has Volume Buttons on the side and may be set to Zero volume? https://www.motorolasolutions.com/en_us/support.html https://www.motorolasolutions.com/en_us/products/two-way-radios/analog-business-radios/portable-radios/bpr40.html#tabproductinfo ..
1/18/2024 7:03:58 PM • Radio... • Answered on Jan 18, 2024
Pin for tzumi earpiece Bluetooth
i need a code for my ear piece
12/29/2023 7:49:36 AM • Radio... • Answered on Dec 29, 2023
JVC KA-310U Logo
2 questions posted
Top JVC Radio Communications Experts
 Grubhead
Grubhead
Mike Cairns
Mike Cairns
Are you a JVC Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Radio Communications
Most Popular Question
unlock nokia 6303 mobile
  • Radio Communications
