20 Most Recent Sanyo VPC-C5 Digital Camera Questions & Answers
Welcome to Fixya
Did you accidentally dropped the camera? You should be able to see options when you plug in the camera to your computer. Try to reset the camera first to factory state as part of our initial troubleshooting.See procedure below:
Select reset settings icon Press set button Reset setting screen should appear then press YES Press the SET button Camera setting should be reset then test the issue again
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Sanyo VPC-C5... | Answered on Jun 11, 2011
User manual for this camera can be downloaded from this link, just click HERE and proceed with the download.
Sanyo VPC-C5... | Answered on Apr 17, 2011
Sorry, what you ask is impossible. SDHC compliant devices contain different hardware and no amount of firmware can overcome that limitation.
Sanyo VPC-C5... | Answered on Oct 06, 2010
The sanyo does not need any drivers, plug it in your computer with usb, turn camera on, select "PC" and press the SET button. now your camera will show up in my computer or computer as a removeable storage device and inside you will find the pictures.
I have the same camera so I know this is how its done.
Sanyo VPC-C5... | Answered on Aug 01, 2009
The correct USB cable for your Sanyo VPC-C5 is part #6450752087 and you may order it from www.partstore.com
Sanyo VPC-C5... | Answered on Jul 24, 2009
I have installed all the software on the disc that came with the camera. Connected the camera to the laptop and the laptop will not recognise. I have photo on the camera I would like to download but cannot!
Sanyo VPC-C5... | Answered on Jan 24, 2009
dear sir
if it's do veruse time just chande yr USB cable or use different usb port after use the sectuation u face same problem chek virus may be yr system is inficted with Trojen or antispy..
dear sir
u have a drvier cd with phone give u when u perchase that phone and when u connect your phone to pc it's show SamsungD900i found then u give path from yr drvier cd it's depend whitch OS u company give all most OS drvier built in CD u have to install software first which also located in CD then connect yr phone to pc as my sujjaction first install full softwre and drvier after connect yr phone to yr Pc and if u allready connect yr phone just plug out then install software and drviers after finesh installaction restart pc then connect yr Phone to OTHER USB prort. it's help u..:)
Thanks
Please vote
jo_Chinmay
Sanyo VPC-C5... | Answered on Jan 02, 2009
If you already tried a new battery, I would suggest cleaning the battery terminals with alcohols and a q-tip first and check for loose terminals. It may be a power switch which unfortunately can't be changed or fixed by the average user. If you want to trouble shoot further and feel you can do it yourself, I will send you links on repair. Otherwise it should be brought in to a reputable repair shop.
Sanyo VPC-C5... | Answered on Nov 17, 2007
No worries, it is possible to recover deleted photos from camera. You may take a look at this guide
How to recover deleted photos from digital camera
the guide helped me before, easy to follow and helped me get back all my photos from my digital camera, hope that it helped you too!
Sanyo VPC... | Answered on Mar 13, 2017
From your description, it appears that the camera may have received an accidental blow, or else there is some foreign matter (sand or suchlike) in the lens mechanism. Either way, you are probably looking at professional repairs, which will be expensive, possibly prohibitively so. It may be more financially viable to replace your equipment.
If you can show accidental damage has occurred, then you may be able to claim on your household insurance.
Sanyo VPC... | Answered on Jun 19, 2016
Recuva (pronounced "recover") is a freeware Windows utility to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital camera memory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
  • Put the memory card into an USB card reader and plug it into the USB port in your computer, then run the Recuva program.
  • Simple to use interface - just click 'Scan' and choose the files you want to recover
  • Easy to use filter for results based on file name/type
  • Simple Windows like interface with List and Tree view
  • Can be run from a USB thumb drive
  • Restores all types of files, office documents, images, video, music, email, anything.
  • Supports FAT12, FAT16, FAT32, exFAT, NTFS, NTFS5 , NTFS + EFS file systems
  • Restores files from removable media (SmartMedia, Secure Digital, MemoryStick, Digital cameras, Floppy disks, Jazz Disks, Sony Memory Sticks, Compact Flash cards, Smart Media Cards, Secure Digital Cards, etc.)
  • Restores files from external ZIP drives, Firewire and USB Hard drives
  • It's fast, tiny and takes seconds to run!
Go to these WEB sites to down Recuva http://download.cnet.com/Recuva/3000-2242_4-10753287.html www.filehippo.com/download_recuva
Sanyo VPC... | Answered on May 07, 2014
I had this same failure. It could be two things, one you bumped the lens an knocked it off the track it rides on. Easier done than you think, or the motor has failed on the lens. You can try to take it apart as I did, but you need time an small tools to do it. It took me three hours to take apart, an two hours to get back together. Dont throw it away I you can fix it. Someone could fix most likely if that is it
Sanyo VPC... | Answered on Mar 24, 2014
There is only one thing I can think of. If it is not this perhaps your camera is defect.
Your camera has a White balance setting. You can put it in Auto, Incand. Daylight, cloudy and Manual.
Check if it is in something other than Auto. If so, put it in Auto, till you think you can improve the colours by putting it in a special setting.
Sanyo VPC... | Answered on Jan 29, 2014
Sanyo VPC-C5 Digital Camera Logo
Popular Tags
16 questions posted
Top Sanyo Cameras Experts
Paul Green
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
View Most Popular
VPC Sanyo
  • VPC Sanyo
Most Popular Question
sanyo vpc t850 camera looking
  • Cameras
