20 Most Recent Sony Ericsson Black Silver Cedar J108i Unlocked Gsm Phone Questions & Answers
Sim contacts may be dirty, either on the card or phone.
remove sim card and GENTLY rub a pencil eraser on the contacts to clean, then test. If you can access the contacts on the phone, do likewise. If not, then you'll have to use an Ether based cleaner, Like electrical parts spray ( available from your local auto parts store) .
be careful not to spray too much into the phone, as once the spray gets inside it takes longer to evaporate. You can counter the time by using compressed air to speed drying of the phone interior without taking it apart.
Hope this helps!!
Sony Ericsson... | Answered on Nov 28, 2013
Hi visit prounlocking.com to unlock your sony ericsson j108i mobile from network lock .here they ask you the network name to which your mobile is locked and the imei number of your mobile .then at last they send you code to unlock your mobile.
Sony Ericsson... | Answered on Jun 16, 2013
Free unlock code is not possible to get for this model.You need to pay to get the unlock code.I would suggest the site Simpleunlocking.com get the unlock code and get free unlocking instructions for your Sony Ericsson WT13I from Mobileunlockguide.com and unlock it easily.
Sony Ericsson... | Answered on May 18, 2013
The wire to headsets can get damaged (usually not visible from the outside, as the wires inside the covering can be very delicate, to keep the size of the wire down) from throwing them in the pocket, purse, etc. Try a set from a friend to make sure the device is still working itself.
Sony Ericsson... | Answered on Dec 02, 2017
i cant install my themes in sony EricssonW395 even in my mobile i dnt have themes folder in filemanager but themes are their in seetings
Sony Ericsson... | Answered on May 30, 2010
If you're referring to the 200bt portable speaker set, this isnt possible. Car stereos are only designed for input over bluetooth not output. Now if it really important to you, you can use a line level adapter to tap into the rear speakers of your vehicle, take that output and plug it into your speakers with an aux cord, or if you have an after market radio you can use RCA cables and a jack adapter to do the same. If you must bluetooth (eg. out of vehicle operation of speakers) buy a cheap bluetooth output adapter (shark makes one) use a small cigarette lighter inverter to power it, and then you can plug your aux jack into it and bluetooth to a speaker set outside of the car. If you use this in conjunction with the speakers car there will be a delay between those speakers and your bluetooth speakers.
Radio... | Answered 7 hours ago
Make sure that the pair on your output device states paired for phone and music. It can still pair for phone and data but not pair to stream music. This is common on android devices especially. If this be the case, unpair the device and forget (delete) the earbuds on your output device. Ensure any bluetooth devices like amazon Alexa, TVs and other common things are powered down. Turn the bluetooth on the output device off, then back on. Search for earbuds and follow manufacturer procedures to sync earbuds. Once found, pair. Ensure when a successful pair happens that they are paired for phone and music. It will tell you on the output device if the pair was successful for both. At this point make sure your volume settings are not muted or all the way down and you should be enjoying music if you have an app playing music.
You likely tripped a fuse or circuit breaker. If you are referring to an automotive type stereo there will be 2 fuses associated with this problem. One is directly on the back of the head unit and is usually 10amp, the other is in your vehicle fuse box usually labeled radio in the diagram.
Sony Ericsson Black Silver Cedar J108i Unlocked Gsm Phone Logo
Popular Tags
12 questions posted
Top Sony Ericsson Radio Communications Experts
Anthony Ward
Anthony Ward
ray gallant
Marvin
Marvin
Are you a Sony Ericsson Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Ericsson Radio Communications
Most Popular Question
phone not recognising sim card window
  • Radio Communications
