20 Most Recent Sharp VE-CG40U Digital Camera Questions & Answers
Fixya does not supply software of any description. Contact the manufacturer or use a USB card reader.
Sharp VE-CG40U... • Answered on Jul 09, 2017
Actually, you didn't. You put in a new 4GB SDHC card. The camcorder works with SD cards, not with SDHC cards. You need to use SD cards, 2GB and smaller.
Sharp VE-CG40U... • Answered on May 03, 2012
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com )
Sharp VE-CG40U... • Answered on Apr 09, 2011
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Sharp VE-CG40U... • Answered on Aug 27, 2010
    The manual doesn't specify a size range for SD cards in your camera, but I've seen 2GB cards offered on line for it. Make sure that the write protect switch on your new card is in the UNLOCKED position and that the card has been formatted for your camera.
    Sharp VE-CG40U... • Answered on Dec 27, 2009
    I bought this camera off ebay. I do not have any software for it. I cannot get it to transfer pictures to my computer. I think i need to install a driver. It is a Sharp 3x Optical Zoom Digital Still Camera VE-CG40. Where can I download a driver?
    Sharp VE-CG40U... • Answered on Aug 09, 2008
    hi there, this is all i could find out at the moment. it could be the latching system i am not sure if its electronic latch or spring. start by looking there if its electronic latch take it in to a shop if its spring latch maybe the end of the spring just needs putting back on. The chances are that a switchcontact or motor is not engaging, and the unit will have to be opened up to be fixed. Oftentimes, with these older units, switch or relay contacts become oxidized over time, and fail.. all this info i found from or fixya site. hope this might help you out.
    Sharp Cameras • Answered on Nov 04, 2017
    Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
    Sharp Cameras • Answered on Sep 02, 2016
    Sharp VE-CG40U Digital Camera Logo
    7 questions posted
    Top Sharp Cameras Experts
    NOEL
    NOEL
    ray gallant
    Are you a Sharp Camera Expert? Answer questions, earn points and help others
    View Most Popular
    Sharp Cameras
    • Sharp Cameras
    Most Popular Question
    keep getting card access error message
    • Cameras
