20 Most Recent
Acer aspire 5733z4851 intel pentium dualcore 4gb 500gb dvdrw 15.6 win Questions & Answers
Why dont i have an internal recording device?
you have an internal recording device. It consists of a built-in webcam and microphone. to make a recording, use the cyberlink webcam program that's pre-installed on your laptop. you'll find it listed somewhere in the start / all programs list in windows 7. also, for sound recording only, the windows 7 audio recorder is located under start / all programs / accessories / sound recorder. select it and click the red record button. also, windows 7 has a feature or program called problem steps recorder. it records activity on your screen including mouse movement. i don't know if it records sound. to access it type psr in the search window and select psr in the search results, then click on start record.
The hard drive is locked
If you mean the Password won't let you in? The Drive is not running? Or you LOST a Key? What is it?
Acer aspire 5733 drivers
Drivers are available from Acer directly. Go to their Web Site and look for your device and download from there.
Drivers acer pew71
on device manager you must uninstall wi-fi driver and then install again.if this not solve your problem change the wi-fi card ; on the back of laptop!!!
Errors PXE-E61 and PXE-M0F
Your
hard drive is missing from the system. Or, just does not recognize it.
The
obvious - Remove any USB devices like drives and any media from disc player.
Its trying to load, but can't find bootable hard drive, CD, or USB...
Remove
the hard drive and re-seat (reconnect). Check BIOS by pressing an F key
during boot. Look on the screen for correct Function key. Might be F2 key.
Verify BIOS recognizes the drive. It must be listed! There is no going
forward if it's not. Check boot order and make internal hard drive first.
Save and restart.
My aspire 5733 goes to a blank screen when i turn it on
Your
The
Remove
Save and restart.
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER.
this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done.
Acer X1110 data projector Standard throw projector..
did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2)
did you read owners manual page 32 yet, errors.
LED codes.?
there are 4 LED, and all 4 matter, projector turned (ON) (not one =1)
also in pairs glowing and also if blinking or not, so read page 32
it tells all that.
my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,.
https://manualzz.com/doc/49497108/acer-x1110-user-manual
some have dust filtler
a shop first cleans is out first, and check fan RPM with and LED tachometer.
this is all SOP.
