20 Most Recent Uniden DECT1560 DECT 6.0 Expandable Cordless Phone System with Caller ID, DECT-1560,DECT 1560 Questions & Answers
Hi Debra,
There are several reasons that this could happen:
1. Your telephone company stopped the service, even though you are paying for it... Ask your telephone company to verify your Caller ID service is current.
2. There may be a problem with your Caller ID service. Ask your telephone company to check to see if there are any problems.
3. Sometimes the caller ID is delayed, try letting incoming calls ring at least twice before answering.
The "charge" light staying on is very unusual, It could mean that the battery is failing, but if it is working properly, don't worry about it.
Best regards,
Bill
Uniden DECT1560... | Answered on Oct 25, 2014
Uniden might have a downloadable manual for your phone.
Uniden DECT1560... | Answered on May 07, 2014
This phone has one mode to configurate the "number of the rings" you need to programer this "time" Enter to this option always search as inside "MENU" follow your user manual also.
Uniden DECT1560... | Answered on Jun 30, 2012
I am having the EXACT same problem.
Uniden Radio... | Answered on May 30, 2020
It all depends on the location. Being VHF and not using a repeater or external antenna, the range is likely less than 10 miles. Using a repeater you might get 50 miles or more. If you are thinking long range communications, you really need an HF transceiver. VHF is essentially for local communications.
Uniden Radio... | Answered on Nov 10, 2019
I have Manuals with the update Sheet $14.95 each (706)270 3829
Uniden Radio... | Answered on Sep 17, 2019
If you get clear audio when close to the receiver, it would appear to be a problem in either the antenna or the receiver. Try a different antenna or relocate the antenna. If you adjusted the VSWR low it doesn't mean the power is radiating correctly. Verticals should be on roof, with roof as ground plane. Mounting on mirrors is ok, but doesn't work as well. Also, if you have sheet metal near the antenna, it acts as a ground reflector and can distort or block the waveform. You might also try it with a different receiver, in case yours has a faulty pre-amp stage. It could also be a power amplifier problem in the transmitter, where it shows 5 watts but isn't putting out that amount. You can check it with an RF watt meter.
Uniden Radio... | Answered on Jul 01, 2019
Trying to wire a dm-452 4 pin mic to a 5 pin uniden ... - Fixya
www.fixya.com/.../t22723929-trying_wire_dm_452_4_pin_mic_5_pin
Jan 6, 2014 - trying to wire a dm-452 4 pin mic to a 5 pin uniden washington -Uniden Bearcat Pro PC68XL ... SOURCE: trying wire a superstar dm-452.
How to wire a superstar DM-452 to a five pin uniden and ...
www.fixya.com/.../t26060852-wire_superstar_dm_452_five_pin_uniden
36 mins ago - how to wire a superstar DM-452 to a five pin uniden and washington - Uniden CB Radios question.
Wire superstar dm 452 mic - Answer
www.dqrkc.com/search/...uniden...pro.../wire_superstar_dm_452_mic
... to a 5 pin how to wire a dm-452 superstar 4 pin mic to a 5 pin uniden washingtonit's not possible to wire 4 wire mics to the uniden 5 wire radios without ...
Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio ...
Uniden Radio... | Answered on Jun 29, 2019
Uniden DECT1560 DECT 6.0 Expandable Cordless Phone System with Caller ID, DECT-1560,DECT 1560 Logo
Popular Tags
9 questions posted
Top Uniden Radio Communications Experts
Robert McClure
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Uniden Radio Communications
Most Popular Question
user manual uniden cordless phone ty
  • Radio Communications
