20 Most Recent Icom IC-7600 HF/6 Transceiver Questions & Answers
SSB power appears when you speak into the microphone
Icom IC-7600... | Answered on Nov 30, 2015
I'd contact Icom, since its under warranty get it fixed
Icom IC-7600... | Answered on Feb 11, 2015
its keeping the finals cool, its doing its job
it is just because your cable is loose, try it after tightning it up
Icom IC-7600... | Answered on Nov 21, 2014
I used to run HRD before Simon sold the rights to the software to a guy in Florida. He now charges for the software. Since your question has been posted recently, I assume you're running the paid version. I suggest you contact customer support. Alternately, you can also go to QRZ. com and join their forum and ask your question there. The new owner of this software frequents that forum . Good luck!
Icom IC-7600... | Answered on Feb 12, 2014
one or both of the extension mic has got some connection issues. I have had similar problems. The fix is to get some electrical contact aerosol cleaner and the extension mic and spray in to the connection holes. failing this you will need to remove the knobs and the screw rings beneath the knobs and Arial then prey the pc board out. from the bottom .NOTE make sure the speaker connections hole is clear of the body . then open it up NOT TO MUCH there is a thin tape wire connecting the front ... to exposes the connections giving it a bit more cleaning and you should be good .
Icom IC-7600... | Answered on Jan 28, 2014
AT-180 ATU is not intended for IC-7300. Icom IC-7300 have a built-in tuner already. maybe you can use a special cable or interface to use the AT-180 on IC-7300.
Icom Radio... | Answered on Apr 21, 2020
Look at pages 16 to 20 in the user manual. This may give you some insight as to haw this may occur. Also, A google search for this radio brings up a lot of useful info. This is a complicated radio as is indicated by the 80 page user manual. It's not one that you can pick up and use right out of the box!
Icom Radio... | Answered on Nov 10, 2019
The link below should help you. Lots of info in the service manual. It's intended to let someone rebuild the radio from the ground up.
Try using an external speaker and see if you have the correct volume level. Radio speakers fail often, especially when used at high volume. The simple fix is to replace the speaker. It is seldom for the audio amplifier to fail this way. Usually they work or they don't.
Here's a link to the service manual - www.shercoares.org > doc_files > manuals > ica110_sm. This may help. Have you checked both fuses? They should both be about 10A. Use a meter to check them. A visible check may not show the fuses open.
I have an icom 91 and still haven't figured it out.
It is easier to use an app and computer and more intuitive.
Icom Radio... | Answered on Nov 03, 2019
http://www.icom.co.jp/world/support/download/manual/
Icom Radio... | Answered on Oct 10, 2019
You need to be a very good technical person with electronics to work on these. The issue is most likely a PLL board issue. You need to be able to troubleshoot to the component level. The service manual appears to be https://www.manualslib.com/manual/738448/Icom-Ic-706mkiig.html
Icom Radio... | Answered on Oct 09, 2019
it is available on web sight..download it.
Icom Radio... | Answered on May 21, 2019
Icom IC-7600 HF/6 Transceiver Logo
6 questions posted
Top Icom Radio Communications Experts
Robert McClure
Vincent G
Vincent G
Ngoro
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Icom Radio Communications
Most Popular Question
no pwer output ssb full power all other
  • Radio Communications
