20 Most Recent
Intel ASUS P4P800S-X 848P Socket 478 DDR 400 ATX Motherboard 3-in-1 Combo (P4P800SXCOMBO) Questions & Answers
Sir i have a problem
You'll first want to make sure that BIOS would load. Turn the MB on with only the memory chips, video card, and CPU (with fans). You'll need to add/remove individual components to isolate the issue. Make sure that the cases's wires are connected to the correct pins on the MB.
Modekort
http://support.asus.com/download/download.aspx?model=P4P800-E%20Deluxe&SLanguage=en-us
I need the user manual
You will be prompted for your OS. On the resulting page, click the [+] beside manuals. Scroll down until you find your language, click the nearest server. Fill in the numbers/letters to access the file. Download.
ASUS P4800S-X Downloads
Recommended psu wattage inreplacement to 300watts psu for asusp4p800s-x
the needed wattage is directly linked to the componets you want to use other then the mobo itself. the main power surges are the CPU (takes 40 to 110 Watts) a graphics card (from 5 to over 150 Watts) the Drives (about 25-30 Watts eachs), the RAM and all the other addons and gadgets you build into your PC. Just add the different Wattages together and give it quiet some headroom. I usually drive this kinds of mobos with 400-550 Watts PSU to be on the save side, if i use a more or less "standard" graphics card, and even more with high sophistcated cards or lots of drives or such.
if you "see" low power (Volts) it might also be a problem with a partwise defective PSU.
Monitor Shows pixelated colors then flashes no input and turnsoff
If it is a desktop, try another monitor and see if you're gonna get the same problem. If its a laptop, connect an external monitor to it. If the other monitor shows the same thing, it means to say that there's just something wrong with your video card. If that's the case, you might as well uninstall and reinstall the video driver. If in the other case, the other monitor's fine then definitely its your monitor. if there's a reset button or a factory reset button available on your monitor then reset it. If the same thing happens, get it replaced.
Problems with Intel 82801EB ICH5 - AC'97 Audio Controller PCI
Try this site
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=949&lang=eng
you will have to enter operating system etc after that it will list all driver for your Motherboard I suggest you download them all and save to a different partition of your hard drive for later if you reinstall windows
Hello Sir/Madam, I have a
You will find the correct drivers for your on board audio here at ASUS: http://support.asus.com/download/download_item.aspx?product=1&model=P4P800S
If you have an audio card installed please post your Model # and I will direct you to the drivers for that as well. If this was helpful please rate, thanks!
Shawn
How long does the Intel i7-930 processor expected to last?
The best way to prolong life of a computer is to blow out dust from the case and cooling fins and power supply regularly, at least every year. That prevents overheating - a primary cause of component failure. Do not overclock.
Do periodic full disk backups and intermediate new file ones. Leapfrog between two external disks. They are cheap. Protect them from fire.
Laptops - same story,, do not block cooling holes by putting on a blanket while lounging. And turn off machine before blowing out dust. Do not use full PSI compressor air! maybe 20 PSI...
Intel D865GVHZ Motherboard won't boot into anything but will turn on
If your Intel D865GVHZ motherboard is not booting and you've tried replacing the CMOS battery, resetting it, reseating RAM, and changing the PSU, it may indicate a more serious hardware issue. You should consider checking the following:
1. Check the monitor: Ensure that the monitor is functioning correctly by trying it with another computer.
2. Check the connections: Verify that all cables, including the power and video cables, are securely connected.
3. Inspect for hardware failures: Check for any visible signs of hardware damage or loose components on the motherboard.
4. Test with minimal hardware: Disconnect all unnecessary peripherals (e.g., external drives, graphics cards) and leave only the essentials connected (CPU, RAM, power, and monitor) to rule out any conflicts or faulty hardware.
5. Try a different RAM: If possible, test with different RAM modules to rule out faulty memory.
6. Listen for beep codes: If your motherboard has a speaker, listen for any beep codes during startup, as they can provide clues about the issue.
7. Inspect the CPU: Check the CPU for any damage or bent pins, and ensure it's seated correctly.
If none of these steps resolve the issue, it's possible that your motherboard or other critical components may have failed, and you may need to consider a replacement or professional diagnostics to pinpoint the exact problem.
Smart response technology
Intel Smart Response Technology (SRT) is used for SSD caching to improve system performance. To use it successfully, here are some steps to consider:
1. SSD Compatibility: Ensure that your SSD is compatible with SRT. It should be a SATA SSD.
2. BIOS Settings: In the BIOS, set the SATA mode to RAID (not AHCI or IDE) before configuring SRT. Make sure your motherboard supports SRT as well.
3. Driver Installation: Before enabling SRT, install the latest RAID drivers provided by your motherboard manufacturer.
4. Backup: Backup your important data because enabling SRT involves data migration.
5. Enable SRT: In the BIOS, set the SRT mode to "Enhanced" or "Maximum" depending on your preference.
6. Initialize SSD: Initialize and format the SSD through Windows Disk Management.
7. Install Intel RST: Download and install the latest Intel Rapid Storage Technology (RST) driver and software for your chipset.
8. Enable SRT in RST: Open the Intel RST software and enable SRT. You should see an option to accelerate your HDD with your SSD.
9. Reboot: After configuring SRT, reboot your system.
10. Verify: Check if SRT is working by opening the Intel RST software. It should show your SSD as a cache for your HDD.
If you're encountering crashes or issues, it's essential to ensure compatibility and follow these steps carefully. If the problem persists, consider seeking assistance from your motherboard manufacturer's support or Intel's support, as it could be related to specific hardware or software conflicts.
How can I troubleshoot a slow computer performance?
The end part of your question makes it sound like an advert.Download and run the Free version of CCleaner. Remove TSR (terminate and stay resident) programs on start up. These are the programs that run in the background.Download CCleaner 6 For Free - Make Your PC Faster & Saferccleaner.comhttps://www.ccleaner.comClean Temporary Files, Optimize & Speed Up Your Computer. Download Now. The No. 1 Tool for Cleaning Your PC. Download CCleaner now. Browse Solutions. View Products. Multiple Payment Options...
