20 Most Recent Icom IC-M36 VHF Marine Radio Questions & Answers
Check PTT switch is working? if working then check power output of your radio. if no power then change PA.
Icom IC-M36 VHF... | Answered on Jul 11, 2016
I would recommend cleaning the contacts on the battery AND on the radio. Scrub the contacts with Contact cleaner in can, or denatured alcohol, or a soft pencil eraser. All work pretty well seperately. Just depends on what you have available.
Icom IC-M36 VHF... | Answered on Jul 11, 2014
Take it to a marine radio service center. Double check the connections, typically when the display blinks on such radios, either it's lost programming or it's misconnected.
Icom IC-M36 VHF... | Answered on Nov 05, 2013
Contact ICOM service at www.icom.com, or take it to a marine radio service center.
Contact the Icom service center. Their main web-page is www.icom.com. From there you can select your geographic area and service (commercial, marine, amateur, etc).
You may have the CTCSS tone squelch enabled so unless a station you're listening to is encoding CTCSS tones, you won't hear the traffic you're expecting.
AT-180 ATU is not intended for IC-7300. Icom IC-7300 have a built-in tuner already. maybe you can use a special cable or interface to use the AT-180 on IC-7300.
Icom Radio... | Answered on Apr 21, 2020
Look at pages 16 to 20 in the user manual. This may give you some insight as to haw this may occur. Also, A google search for this radio brings up a lot of useful info. This is a complicated radio as is indicated by the 80 page user manual. It's not one that you can pick up and use right out of the box!
Icom Radio... | Answered on Nov 10, 2019
The link below should help you. Lots of info in the service manual. It's intended to let someone rebuild the radio from the ground up.
Try using an external speaker and see if you have the correct volume level. Radio speakers fail often, especially when used at high volume. The simple fix is to replace the speaker. It is seldom for the audio amplifier to fail this way. Usually they work or they don't.
Here's a link to the service manual - www.shercoares.org > doc_files > manuals > ica110_sm. This may help. Have you checked both fuses? They should both be about 10A. Use a meter to check them. A visible check may not show the fuses open.
I have an icom 91 and still haven't figured it out.
It is easier to use an app and computer and more intuitive.
Icom Radio... | Answered on Nov 03, 2019
http://www.icom.co.jp/world/support/download/manual/
Icom Radio... | Answered on Oct 10, 2019
You need to be a very good technical person with electronics to work on these. The issue is most likely a PLL board issue. You need to be able to troubleshoot to the component level. The service manual appears to be https://www.manualslib.com/manual/738448/Icom-Ic-706mkiig.html
Icom Radio... | Answered on Oct 09, 2019
Icom IC-M36 VHF Marine Radio Logo
7 questions posted
Top Icom Radio Communications Experts
Robert McClure
Vincent G
Vincent G
Ngoro
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Icom Radio Communications
Most Popular Question
ic 36 wont transmit
  • Radio Communications
