20 Most Recent Intel Biostar P4TSE-D2 865 Chipset Mainboard for Pentium 4 533/800 FSB w/ 8X AGP and Serial ATA (MBSK478BIOP4TSED) Motherboard Questions & Answers
Compaq presario 1700
be sure that your cables are in the right place or your drive is bad
5/14/2014 11:28:14 PM • Intel Biostar... • Answered on May 14, 2014
Lenovo t410 reset bios password
Follow these steps to clear the password:NOTE: These steps also clear CMOS.1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.2. Disconnect all external devices connected to the computer.3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet andthen unplugging the AC adapter from the computer.4. Remove the battery 5. Remove the real-time clock (RTC) battery 6. Wait approximately 30 minutes.7. Replace the RTC battery and reassemble the computer.8. Connect AC power to the computer. Do not reinsert any batteries at this time.9. Turn on the computer.All passwords and all CMOS settings have been cleared.
8/6/2012 7:55:38 PM • Intel Biostar... • Answered on Aug 06, 2012
Lenovo g570 bios password
click start type cmd press enter
At command prompt type debugyou will get a - prompt where you can type the following (<enter> means press enter not type enter*)A <ENTER>MOV AX,0 <ENTER>MOV AX,CX <ENTER>OUT 70,AL <ENTER>MOV AX,0 <ENTER>OUT 71,AL <ENTER>INC CX <ENTER>CMP CX,100 <ENTER>JB 103 <ENTER>INT 20 <ENTER><ENTER> just hit enter on this lineG <ENTER>Q <ENTER> Basic BIOS password crack - works 9.9 times out of ten
the below passwords.
AMI BIOS
A.M.I.AMIAMI_SWAMI?SWBIOSHEWLITT RANDLKWPETERPASSWORDOder
AWARD BIOS
01322222589589589721595595598598aLLyaLLYALLYALFAROMEaPAf_awardAWARD SWAWARD PWAWARD_SWAWARD?SWAWKWARDBIOSTARCONCATCondod8ondjonetHLTJ64J256J262j332j322KDDLKWPETERlkwpeterPINTpintSERSKY_FOXSYXZTTPTHAZAAADAZBAAACAZJAAADC
Russian Award Passwords:
% p%% p%
IBM APTIVA BIOS
Press both mouse buttons repeatedly during the boot
PHOENIX BIOS
phoenix
OTHER BIOS
ALFAROMEBIOSTARbiostarbiosstarCMOScmosLKWPETERlkwpetersetupSETUPSyxzWodj
SOME COMPUTERS WITH TOSHIBA BIOSHold down the Shift key as the computer is booting. hope this helps
7/2/2012 9:29:11 PM • Intel Biostar... • Answered on Jul 02, 2012
I don't setup AGP.
Here is a direct link to the drivers you need:http://www.biostar-usa.com/mbdownloads.asp?model=p4tse-d2
6/2/2012 12:22:05 AM • Intel Biostar... • Answered on Jun 02, 2012
tip
Break BIOS Password
Break BIOS Password
A user may also put a BIOS password preventing you to even enter the system but if you wish to access the system do not worry we you can still do it. However, I only recommend this trick for your own personal use.
What is BIOS?
Bios stands for Basic Input Output System and is a firmware code run by a PC when first powered on, which is a type of boot loader. The primary function of the BIOS is to identify and initialize system component hardware (such as the video display card, hard disk, and floppy).
How to Break a BIOS Password?
The following steps work absolutely fine for a Desktop and are the easiest of all.
Steps:
• Shut down the computer and take out all the plugs connected to electricity.
• Open up the CPU cabinet and locate the CMOS battery on the motherboard (it will be a silver circular battery just like a button cell).
Remove the battery and keep it out for some 2-3 minutes as this will flush out the CMOS memory which stores the BIOS password and all other configurations.
• Now place the battery back and start the computer normally.
Steps for Laptop:
• Open up the BIOS at the time of booting.
• There are some backdoor passwords which the manufacturing company had set that will be accepted by the BIOS. You will just need to know the make of your BIOS. Try out the passwords from these lists.
List of Award BIOS backdoor passwords:
BIOSTAR, AWARD_SW, AWARD SW, AWARD PW, CONDO, LKWPETER, J262, 01322222
List of AMI BIOS backdoor passwords:
AMI, AAAMMMIII, BIOS, PASSWORD, A.M.I., CONDO
List of PHOENIX BIOS backdoor passwords:
phoenix, PHOENIX, CMOS, BIOS
You may also want to try this utility CmosPwd 4.8
Password for BIOS DELL M1210
Hi, all i could find was a service manual:
http://support.dell.com/support/edocs/SYSTEMS/xpsm1210/en/SM/index.htm
It sometimes help to remove the cmos battery from the
mainboard for 15 minutes.
This will clear the password and reset the bios.
If it is a biostar mainboard you can download a manual and drivers here:
http://www.biostar-usa.com/mbdownloads.asp?model=P4TSE-D2
If none of this help you have to contact
the dell support in your country and explain them your problem
they are mostly helpfull vith that.
9/12/2011 7:02:30 PM • Intel Biostar... • Answered on Sep 12, 2011
Helo
Greetings.. It would Help if you were to Explain your Problem in detail.
for example. What is the Mainboard doing?
6/22/2011 9:02:36 AM • Intel Biostar... • Answered on Jun 22, 2011
Bios password acer notebook
3/2/2011 3:52:16 AM • Intel Biostar... • Answered on Mar 02, 2011
2answers
Reset bios password of acer aspire 5720 notebook
i had same problem and i started to worry but then i tried doing it in capitals and for some reason it worked have u tried doing it in capitals?
1/25/2011 3:17:27 PM • Intel Biostar... • Answered on Jan 25, 2011
Nero 7 serial number
I cannot supply you with Nero 7 serial number BUT -
You can download for a free copy Nero 9 software from this WEB site :-
http://www.nero.com/eng/downloads-nero9-free.php
5/22/2010 10:47:38 AM • Intel Biostar... • Answered on May 22, 2010
2answers
Password
Somewhere on the board is a small button cell (a battery). Remove it carefully and leav it out for about 5 minutes then refit it (make sure you refit it the correct way around or you WILL damage the board). This will erase the bios settings. When you first reboot, it should rewrite the bios settings for you and boot as normal. Sometimes this can happen where the bios has a damaged code precursur which defaults to a password, resetting the bios will clear this.
3/14/2010 1:56:57 PM • Intel Biostar... • Answered on Mar 14, 2010
I have two frontpanel usb port... show me the
iwant to connect my speaker
1/30/2010 5:05:39 AM • Intel Biostar... • Answered on Jan 30, 2010
Usb and audio don't work. The check utility
Go to bios level and enable the USB and Sound may solve your problem. Also install the latest drivers for the same to solve your problem.
Revert back for more assistance.
1/18/2010 7:02:08 AM • Intel Biostar... • Answered on Jan 18, 2010
Password Problem
REMOVE THE CMOS BATTERY FOR 5 MINUTES THIS WILL CLEAR THE PASSWORD.
11/4/2009 11:28:03 PM • Intel Biostar... • Answered on Nov 04, 2009
No display in my board any time massage view
this may be caused by 2 things: 1. corrupted OS 2.overheating CPU possible solutions: 1. reinstall/repair system using install disc 2. clean CPU fan and apply new thermopaste on base of a radiator ![DON'T scratch the old one with anything sharp, DON'T use alcohol to do it]! then use any temp measurement program to see cpu temp. if above 50 C use a bigger fan
9/24/2009 1:32:46 PM • Intel Biostar... • Answered on Sep 24, 2009
My toshiba tecra m5 is asking for passward i did not put passward
Is this on Login or just Administration password?
7/13/2009 2:25:18 PM • Intel Biostar... • Answered on Jul 13, 2009
Clean bios password
You need to remove the CMOS battery located on the motherboard a nd re insert again..it will reset ur BIOS password...
4/16/2009 3:23:54 AM • Intel Biostar... • Answered on Apr 16, 2009
My computewr has failed to install halo game,
i want driver for asus p4xp-x
3/2/2009 1:11:51 PM • Intel Biostar... • Answered on Mar 02, 2009
Aceraspire 5720 will only charge to 42%
You need to change the battery definitely. The battery is on the bottom of the laptop There will be a latch on the bottom that you have to push with one hand and hold it and the other hand you'll take the battery out and then you can put another battery in its place.
2/5/2009 4:55:20 PM • Intel Biostar... • Answered on Feb 05, 2009
Intel Biostar P4TSE-D2 865 Chipset Mainboard for Pentium 4 533/800 FSB w/ 8X AGP and Serial ATA (MBSK478BIOP4TSED) Motherboard Logo
29 questions posted
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
don 39 t setup agp
  • Computers & Internet
