20 Most Recent
Tecnik TKC9425 Stainless Steel Electric Kitchen Range Questions & Answers
Fault coming up as "E1"
First disconnect power for at least30 seconds. Re-apply power and observe for at least one minute. If codere-appears, you need to replace control board (also called ERC or clock).
For draining problem: Verify drainpump operation - verify that the pressure switch hose is in good condition andproperly connected to tub and pressure switch. Please check these -
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves, pressure switch, drainpump, flow meter,
and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuringthe resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
If you findanything, replace failed component.
Hope this willhelp you. Good Luck.
