20 Most Recent
Adapters.com Netgear WG511 54 Mbps Wireless PC Card 32-bit CardBus [ Netgear WG511NA Wireless ] (110390) Questions & Answers
The ploblem is In need the solution of wire less
I presume you need Internet access in this house using a wireless network.
The best place to locate the wireless router is in a spot centrally located where the radio signals can reach the rooms where the computers are located. The DSL or cable modem/connection would also need to be in this area so it can connect to the wireless router.
If the wireless router is in a multi-storey house and the floor slab and walls are concrete and/or brick, then the radio signals will be impeded and the signal strength to some rooms will be weak.
In such circumstances, it maybe better to install network cables from these rooms to the wireless router, or install wireless access point repeaters to increase wireless coverage.
If you are not sure how to setup and install this network, then I suggest you get help from a computer savy friend or from your computer friendly shop.
CAN NOT CONNECT WIRELESS ADAPTER
i connect to the wireless adapter its very easy go to the wireless adapter & refresh to the network list if your notification area will have a wire less network when the wireess adapter search any connection then you see a option connect then click connect
How to put profile picture?
Click on "My Profile" in top right corner.
Then click on "Edit Profile" in top left corner.
Scroll down the page to the "Upload your Profile Picture" section.
Browse for your favorite picture.
Click on "Save Changes" blue button at the bottom of the page.
After charging d battery when we remove cabele
the battery sounds like it has bad battery memory and needs to be replaced. Before you replace it look for software to give you the battery's status (how much charge it holds out of how much it should hold by design. for exaple i am using ubuntu linux and my battery reads
Capacity: 29% (Poor)
Current charge: 14.3 Wh
Last full charge: 14.3 Wh
Design charge: 48.8 Wh
Charge rate: 10.0 W
now that is my bad battery for staying at home and leaving it plugged in all the time (that kills the battery) i have another battery that reads
Capacity: 97% (Good)
Current charge: 38.8 Wh
Last full charge: 47.5 Wh
Charge rate: 5.5 W
it is my battery for travel. the difference between the two is that the battery that reads Capacity: 29% (Poor) only lasts about 40 minutes but the battery that reads Capacity: 97% (Good) lasts 3 hours. you probably have a low Capacity.
It does not show wireless icon at all
(Post ur Operating System along with the problem and the Brand name of ur laptop)
Chk whether the wireless is turned On or not.
Certain laptops requires manual command from the user to turn on the wireless.
If possible try to remove the wireless from ur laptop and try to re-install it and re-install the drivers also.
