20 Most Recent Motorola Headset Mic Vl130 Pr400 Bpr40 Dtr410 Dtr 410 Questions & Answers
PeteD.
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
Motorola Headset... | Answered on May 12, 2015
Yes it will. Here are the instructions for pairing it.
How to Pair a Motorola N136 Bluetooth Headset ' Techwalla
www.techwalla.com > ... > Entertainment
The Motorola N136 headset, which has been updated as the nearly identical HS850, gives cell and smartphone users wireless hands-free usage with Bluetooth ...
Motorola Radio... | Answered on Dec 06, 2020
I am not sure about this Motorola device but usually, it's possible to listen to music even on cheap chinese BlueTooth headsets.
Motorola Radio... | Answered on Aug 26, 2020
This is likely because your radio's battery has lost enough power that it cannot fully power the headset and the radio both. Or there is a component in the headset or radio which is getting overheated and will not function properly. Try the headset on another radio at the time of failure and see if it is still in failure mode on the other radio. Or try changing the battery to a fully charged battery and see if the headset then functions correctly. These test will help you determine which component is failing.
Motorola Radio... | Answered on Mar 11, 2020
The FCC ID won’t help you find the info you’re looking for, you’ll need to find the model number and possibly the software version number. This info should be on the back of the unit or maybe inside the battery cover.
Motorola Radio... | Answered on Feb 05, 2020
Long press P3 and check key sign will be goes OFF, now your keypad is unlock.
Motorola Radio... | Answered on Nov 03, 2019
please, try long press P2 button, to unlock your radio,
and re-try,
Thank you,
With Regards,
jack
It requires the radio programming program. You must take it to a dealer. It will cost a bit to be reprogrammed, call in advance.
Motorola Radio... | Answered on Oct 04, 2019
Entering Front Panel Feature and Button
Configuration Mode
If your radio is turned ON, turn it OFF. Press and hold the side
programmable button 1, and turn your radio ON. A tone is
heard, indicating that your radio is in Feature and Button
Configuration Mode. The indicator illuminates and the
"BCKLIGHT" is displayed on the radio LCD screen.
Whenever the radio is turn on, it initiates a self-test routine which checks the RAM, EEPROM
hardware and EEPROM checksum. If Self Test passes, the green LED flashes once and a Self-Test
Pass Tone is generated. If unsuccessful, the red LED flashes rapidly and a Self-Test Fail Tone is
heard
You may need the programing software to do the reset the manual does not give you any info on resetting the radio
Motorola Radio... | Answered on Oct 03, 2019
No. Your Talkabout radio operates on UHF and your wife's walkie talkie is a VHF radio operating on exclusive business frequencies.
Motorola Radio... | Answered on Sep 26, 2019
Hi PC Bedwell, check the battery charge, it may be needing to be replaced, likewise, control the charger
I hope you can solve the problem
Regards Franco Dosil
Hola PC Bedwell, comprueba la carga de las bater?as, puede estar necesitando ser reemplazadas, de igual manera, controla el cargador
Espero puedas resolver el problema
Saludos Franco Dosil
Motorola Radio... | Answered on Sep 20, 2019
Check your Private Line (aka interference eliminator code, tone code, PL, quiet call). It sounds like you have one radio set with a PL setting and the other one is open squelch (no private line). All settings for frequency and PL code need to be the same between the two radios.
We don't have a manual for the T3, but I am attaching one for the T5, which may be similar. http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/TLKR-T%20series/Static%20Files/T5%20Manual%20EU.pdf
Best regards.
Motorola Radio... | Answered on Aug 31, 2019
The CLS has preprogrammed frequencies. The Bao can be user programmed. If both are Uhf, the Bao must match the CLS unless one of the CLS frequencies is already in use in the Bao. So, are you already using CLS and adding radios? You need the actual frequency and tone code. If you do not understand, contact a dealer like us, local is even better! Channel 1 is only an indicator, not a frequency. [email protected]
Motorola Radio... | Answered on Jun 16, 2019
Motorola Headset Mic Vl130 Pr400 Bpr40 Dtr410 Dtr 410 Logo
1 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
remove circuit board in bpr40
  • Radio Communications
