20 Most Recent
Yaesu Ft 1900r Vhf Mobile 55 W Two Way Radio Ft1900 R Questions & Answers
I cant talk on any frequency over 148.000 anyone know why?!
This is an Amateur (Ham) Radio 2-meter Transceiver. It will only transmit on the 2-meter Amateur band (144-148 MHz) but has expanded receiver coverage from 136-174 MHz which includes Public Service and Commercial 2-Way Radio bands. Please note that an Amateur License is required to operate on the 2-meter Amateur Band.
Any frequency over 148.000 i cant talk on, i can just listen. anyone know why?yaesuft1900r
The Yaesu FT1900R is an Amateur (Ham) Radio 2-meter Transceiver. Although the receiver covers from 136-174 MHz, will only transmit from 144-148 MHz. Please note that you do need an Amateur (Technician Class or above) License to transmit on the 2-meter Amateur Band. You no longer need to pass a Morse Code test to get an Amateur License. You still have to pass a written exam, but that isn't difficult if you are willing to study a bit. Contact your local Ham Radio Club or the American Radio Relay League (A.R.R.L.) for more information.
Yaesu 101ex has no reccive or transmit
The problem is likely the TX/RX relay. If it is old (and I am sure it is) the contacts likely need to be cleaned, or the relay replaced. It is a common enough relay if you want to replace it. Also, pull each PCB card and clean the contacts with a pencil eraser. Pink erasers are OK but the white ones are better as they aren't as abrasive.
Hope this helps, VE3CMQ
Yaesu ft-100d. Does not rx or tx. Frequency readout blinks on rx. On tx frequency blanks out and icon upper left indicates tx-off. full reset and no change. exchanged local unit and no change.
I am not sure, but this usually indicates that the PLL has lost lock. These days, it could be as simple as a poorly soldered connection. I don't recommend that you try repairing this yourself as there are essentially no user serviceable parts in radios these days.
Radio repairs these days have come down to board swapping because the parts are so tiny that humans have a hard time replacing (and in some cases, seeing) the parts. Yaesu US has a very good reputation for quality repairs so I'd suggest you send it there. They will likely just swap a board out, but that will be less expensive than having someone spending 10 hours trying to find the problem and repairing it. I know, as I work in a radio shop, and if it isn't something real simple, all we can do is do a board swap.
My yaesu ftm 3200 will not power up
Check the fuses and the power supply. Make sure that the power supply has enough capacity to run the radio, at least 20A! Make sure that the power supply is putting out 13.6V.
If you were unfortunate enough to hook the power leads up backwards, then a trace may be blown off the circuit board internal to the radio. Also, it is likely that the reverse polarity diode inside has shorted out. This may cause the fuse to blow when you apply power. If it has blown, it likely took the the trace out inside the radio.
If the power supply and fuses are OK, unless you are competent technically, the only recourse is to take the radio into a shop and get them to fix it. If you were upgrading the firmware inside the radio when it happened, then the radio is likely non-repairable.
I don't recommend ever upgrading a radio's firmware! If it isn't broken, then don't fix it!!
