20 Most Recent Intel 486 CPU Cooler CPU Cooling Kit Questions & Answers
I can't instal windows 95
IIRC the very early Windows 95 installation required CD-ROM drivers prior to Win95 set up, this was achieved using the supplied diskette.
The work-around for this issue is to do the initial install on a different system and transfer the HDD to your 486 system, this must be done BEFORE windows configures the driver set OR setting the drivers to MS default is required following completion of setup (on surrogate system).
1/26/2009 3:58:53 AM • Intel 486 CPU... • Answered on Jan 26, 2009
The Green led on the motherboard is ON, and the Intel D915gav won't turn on even though it was working well the day before.
There are several possible reasons why your Intel D915gav motherboard won't turn on, even though the green LED on the motherboard is on. Here are some troubleshooting steps you can try:
  1. Check the power supply: Make sure the power supply is turned on and connected properly to the motherboard. Verify that the power cable is securely plugged into the wall socket or power strip and into the power supply unit. Also, check if the power supply is providing the correct voltage to the motherboard.
  2. Inspect the RAM: Check if the RAM is seated properly in the slots. Remove the RAM and re-insert it, ensuring it's seated firmly in place. You can also try booting with one RAM stick at a time to see if one of them is faulty.
  3. Check for loose connections: Check all cables, connectors, and wires to ensure they are properly seated and secured. Make sure there are no loose wires, frayed cables, or damaged components.
  4. Test the power button: If the power button on your computer is not working, the motherboard won't turn on. Try connecting the power button pins directly to the motherboard to see if it turns on.
  5. Clear the CMOS: Try clearing the CMOS memory to reset the BIOS settings. This is done by removing the CMOS battery for a few minutes, then re-inserting it and restarting the computer.
  6. Check the CPU: Make sure the CPU is seated correctly in the socket and that there is no thermal paste residue between the CPU and the heatsink. If there is, clean it off and reapply fresh thermal paste.
If none of these steps resolve the issue, it's possible that the motherboard or another component has failed and may need to be replaced.
3/7/2023 2:54:27 PM • Intel Computers... • Answered on Mar 07, 2023
Hovedkort: Lite-On Tech. 08FCH (mPGA 478)
Det ser ut til at hovedkortet ditt er ganske gammelt og ikke lenger st?ttes av produsenten, og det kan v?re utfordrende ? finne drivere for det. Du kan pr?ve ? s?ke etter drivere p? Lite-On Techs nettsted eller p? produsentens nettsted for hver av de komponentene du nevner (Multimedia Sound Controller og Intel 82865G Graphics Controller). Alternativt kan du pr?ve ? bruke en driveroppdateringsprogramvare som kan skanne systemet ditt for ? finne og laste ned de manglende driverne automatisk. Imidlertid b?r du v?re forsiktig n?r du laster ned og installerer driveroppdateringer fra tredjeparts nettsteder, da de kan v?re up?litelige eller inneholde skadelig programvare.
3/3/2023 10:15:20 PM • Intel Computers... • Answered on Mar 03, 2023
3answers
Looking for someone to help me determine a possible motherboard fault, any takers?
You wont find any schematics for motherboards online. The market is too competitive and proprietary. The most common tool in troubleshooting a motherboard now days I would say is infrared camera's. They use them to look for shorts in the components and heat in the circuit board traces.
12/3/2022 6:02:09 AM • Intel Computers... • Answered on Dec 03, 2022
Compatible motherboard and CPU with a Sony Vaio VGN-N220E laptop ?
Hi, please call geeksquad to request that they check for compatible motherboard within their inventory: 1 (800) 433-5778. This should help you reach your goal. Thank you.
10/1/2022 8:54:39 PM • Intel Computers... • Answered on Oct 01, 2022
Avira Antivirus Pro 2022 Crack
8/7/2022 7:13:28 PM • Computers &... • Answered on Aug 07, 2022
2answers
Mp4 player not working
Check your MP4 player's system requirements. Some MP4 players are only capable of working with certain operating systems and hardware, so refer to your player's documentation to ensure it is capable of functioning with your PC. Change the USB port your MP4 player is connected to if you have confirmed your PC can function with your MP4 player. Disconnect other USB devices, and try connecting your player to another USB port if you are still having problems. Try restarting your PC if it is capable of working with your MP4 player. Restarting your PC resets non-functioning USB ports, which may be your problem. Make sure your USB cable is connected properly. If your player requires you to install drivers, make sure you install them. Try connecting your player to another PC to see if the new PC recognizes it. If it does, chances are your computer does not support the hardware necessary to run your player. Reset your MP4 player if your PC is still unable to recognize it. Resetting your player varies depending on the manufacturer and model, so refer to your player's documentation. Contact your player's manufacturer if you are still unable to get it to work with your PC. http://applestore.altervista.org/mp3mp4.pdf
6/9/2022 2:57:40 AM • Intel Computers... • Answered on Jun 09, 2022
Is intel i3 processor sufficient for this site,slow collecting points
WHAT SITE? WHAT POINTS? IS THERE A PROBLEM STATE IT IN DETAIL. personally who needs points, ? can't buy beer with points, so are worthless.
1/20/2022 6:54:32 PM • Intel Computers... • Answered on Jan 20, 2022
Can my P5S-MX SE motherboard go with Intel E5400 pentium dual core 2.7 ghz?
wrong that mobo is not blue and is not made by intel.com at all it is ASUS..com says so on the mobo and at their web sets all mobo sold by them from 1995 to 2022, have QVL LIST ON CPU, ALL DO THERE. SO FIND IT OR ASK THEM. TOOK ME 3 SECONDS TO FIND THIS GOOGLE https://www.asus.com/us/SupportOnly/P5S-MX%20SE/HelpDesk_CPU/ QVL = QUALIFIED VENDOR LISTS, RAM OR CPU FROM 1995 TO NOW, AND ASUS.IS THE BEST DYI MOBO MAKER BAR NONE, AND GIGABYTES TOO. 2ND FIDDLE.
1/20/2022 6:29:39 PM • Intel Computers... • Answered on Jan 20, 2022
How to connect OLD hard disk 80GB AT HDD ExcelStor Jupiter Callisto J880 K2B5P3H IDE ID13439 to intel core2 duo? MY SECRET PC MODEL NOT TOLD.
CORE2 NOT CORE CORE 2 IS 2006 TECH.(first)A 13 year old PATA drive, reviews 2005 yah a relic. No PC model told ,desktop or laptop? 2006?intel only mobo ?. not told|I will not cover, mobo with via or sis or Nforce chips with IDE support. just intels. and not Marvell chips on the mobo, or the like. 80GB AT HDD ExcelStor Jupiter Callisto J880 K2B5P3H IDE ID13439it just plugs into a IDE (PATA) 40pin port. it is NOT A SATA drive. ( i BET IT IS BAD)there are only 3 ways to use any PATA (ata ide)DRIVEA MOBO WITH THE 40 PIN PATA PORT.THERE.OR AND PCI ADAPTER PATA THERE. (WITH BOOT ROM IF NEEDED)OR A SATA TO PATA DIRECT ADAPTERTHAT IS ALL There is. (got the last pata drive on earth not dead, is that it?the last real intel mobo with PATA ports is ICH7and is CORE2. P31 +ICH7 chip set.?(yes some PCs had Marvell chips on board to add IDEto ICH8 PCs that intel ended, IDE forever Ich7 south bridge has old IDE pataICH8 mobile has IDE BUT NOT ON desktops and others.ICH9 may 2007 ends IDE in the intels chips forever..NO PC MODEL TOLD OR IF DESKTOP WHAT MOBO IS THERE.IF EVEN IF A SERVER, NOT TOLD.IT JUST PLUGS-IN, SET JUMPER TO SLAVE IS 2ND DRIVE.NOT TOLD IF IS BOOT DRIVE. ETHER.
1/20/2022 6:23:01 PM • Intel Computers... • Answered on Jan 20, 2022
What are the steps to enabling the start window on an intel inside nextbook
no OS told at all stinking w8 yes then load start8 or start 10 or start11, and now PC acts like w7 ive run it for 7 year upgrades 8 to 11 $5 cost. in the run box type system or winver and see what OS this is w8 is free upgrade to 10 on most PC;. or learn to use lower left win key on w8 to do the tasks. https://www.stardock.com/products/start10/?utm_source=stardock-software&utm_medium=start10&utm_campaign=in-app-website&Referer=stardock
1/20/2022 6:19:18 PM • Intel Computers... • Answered on Jan 20, 2022
Please help latest version of vga card mobile intel 965 express chipset family on my laptop compaq v3000 thank you....
965 is relic, PC, intel chip set no longer supported by intel now. real; name by HP. Compaq Presario V3000 Notebook PC (2007) 15 years old and no HP support for a long time, your question lacks a clear question. are you asking for new GPU card, sorry there is no card. in this laptop. are you asking for GPU drivers. yes, hp.com go there and get them. HP.com the complex URL there is no card ,yes there is GPU chip but no card. hardware GPU Mobile Intel Graphics Media Accelerator X3100, Unified Memory Architecture (UMA) with shared video memory: up to 64 MB on computers with 512 MB or less of system memory, up to 128 MB on computers with more than 512 MB of system memory (memory size is dynamic change) Intel 82852/82855 GM/GME Graphic Controller that is and intel GPU,only if it runs just run it and leave it alone, there are no upgrades on relic PC, (ram sure) 2GB max total 2x1GB. EOL end of life, as most are 10 years old business PC longer, a tad
1/20/2022 5:55:29 PM • Intel Computers... • Answered on Jan 20, 2022
Intel motherboard H57H-AM which has a 8 pin connecter shows int_spk.when i connect speaker terminals into this it will not get audio music. connecter pin details not available.please help me.
NO OS told at ALL, XP to W11 what is the goal here? h57 is good chip set, w10 runs it. series 5 it is called google the manual yet (w10 support for the intel chips here only) not sound. why did you say Intel???? a blue mobo from intel? Acer????green board and Acer white ink clear as day? ASPIRE? acer does not publish pins, nor does any OEM PC. asus and asroc, mSI and gigabytes do DIY mobo have real manuals and OEM do not, the trouble is not telling 2 things lost the PC did you, OEM case and all that gone? bought a rouge mobo from ebay , and is not DIY but pulls from ACer PC and not told by the seller, 99% of the time they lie by omission. where did you get the mobo, and was it just a mobo bought.????? history mattes for sure acer mobo, that has no parts lists at all . best way i to look up mobo numbers is google to see sellers that not lie. (sells mobo and no manual and for sure no pinouts and driver none) 1st hit Acer Veriton M490G M498G M680G S680G Q57H-AM Motherboard H57H-AM + I/O SHIELD Vertiton means desktop. and acer.com has manuals and driver there for all my ANSWER ARE USA, what you get in your country if not 1 clue. nor want to know 50 contries, laws. on such. acer.com support desktop veritron M series. 490G bingo https://www.acer.com/ac/en/US/content/support-product/2106?b=1 windows 7 max 32 or 64bit. no w8 no w10 no w11 , period and ever. 2010 audio driver is there, and must be loaded for sound to work. why not just use rear of PC spackers out green jack and forget lost internal or front speaker jacks no PC told not told if all acer cables were lost. no clues at all but mobo raw number. hard nut to crack, and did it. 2009 made load the driver to w10 using w7 to w10 compatibility mode and toss a coin, ms tells how, endless. acer only tells how to plug-in their PC cables. only no detail at all, never buy acer for that reason alone only a lame basic manual,. there,
1/20/2022 5:43:50 PM • Intel Computers... • Answered on Jan 20, 2022
I just failed to locate audio drivers for intel celeron E3400 in internet can someone help
NO PC told ,,maker and model\ (i guess, DIY mobo PC desktop?) if only a mobo say so and tell its maker (asrock) and model. we can not guess any of that asrock.com all are there, go there get them same answer on any PC, find OEM website (google) the go there and tell them what you have. and BINGO. drivers that fail PnP , must be obtained at asroc or get infected you will.
1/20/2022 5:16:35 PM • Intel Computers... • Answered on Jan 20, 2022
Intel r pentium r 4 cpu 1.80ghz driver download free
no PC told maKER AND MODEL IF IT IS JUST BLUE OLD INTEL MOBO THE MODELS CLEARLY STAMPED ON IT AND JUST RECENTLY INTEL ENDED SUPPORT . d945gm? like this. READ the labels top of mobo see what u got. 2006 , intel did drivers from them to 2020. and it ended. https://www.pcdied.com/w10/D945-GPM/images/94508.jpg
1/20/2022 5:03:41 PM • Intel Computers... • Answered on Jan 20, 2022
What equipment goes to intel Pentium processor I i have a monitor mouse and keyboard
the question makes no sense at all sorry. try again. you LOST your PC? really?>
1/20/2022 4:59:21 PM • Intel Computers... • Answered on Jan 20, 2022
2answers
My vlc media player crashes frequently ?the
I think k-lite is the best replacement..... you can download it from http://www.free-codecs.com/k_lite_codec_pack_download.htm
11/17/2021 2:25:32 AM • Intel Computers... • Answered on Nov 17, 2021
I having windows 10 pc .in my doesn't support miracast after intel update,also in my pc network is also on,but also didn't support,please tell solution
Intel stopped supporting the technology after Microsoft began to support in in Windows 10 in native mode. You may be encountering legacy issues. Mirasoft is a way of broadcasting via WI FI without going through a router. You well may have to resort to an HDMI connection between the devices if compatibility issues persist. Or acquring a Mirasoft transmitter dongle. https://answers.microsoft.com/en-us/windows/forum/windows_10-win_continuum-winpc/your-pc-does-not-support-miracast-despite-driver/57c49ed9-4bed-4ae1-a793-c008cecb30f8
4/11/2020 4:09:50 AM • Intel Computers... • Answered on Apr 11, 2020
Intel 486 CPU Cooler CPU Cooling Kit Logo
1 questions posted
Top Intel Computers & Internet Experts
Steve Nordquist
Steve Nordquist
Marvin
Marvin
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
instal windows 95
  • Computers & Internet
