20 Most Recent GE 30524ee3 3 Headset Corded/2 Cordless Dect 6.0 Answering Sys Lcd Display Used Questions & Answers
Not a problem. Take the base unit with you to Radio Shack and they will get you a proper replacement. (The numbers on the plug in to the unit will say how many volts Direct Current are required to operate is properly and the tag underneath will also state how many milliWatts of power are required at that voltage.) The key is buying the proper plug in end that fits the socket. Radio Shack has units with several socket tips so you may select the proper one. Make sure the polarity of the socket plug you use matches the wire polarity... the stripe on one side of the power cord is the + side on the socket tip.
GE 30524ee3 3... | Answered on Apr 04, 2015
what is the model number ?
GE Radio... | Answered on Feb 01, 2018
Generally, you need to read the instructions for the camera or whatever the Bluetooth device is.
Roughly speaking though.
Settings - Bluetooth - Search on the Android, iPhone, Windows phone whatever.
With camera, speaker, headphones or whatever the Bluetooth device is, you have to press a button on that device to send out the signal. In my Bowers and Wilkins T6 Speakers, there is a button on the top with the Bluetooth symbol on it.
When the Android device recognises it, click Pair, and if it asks for a code, the Default is '0000', (four zeros, no quotes).
GE Radio... | Answered on Nov 19, 2016
This radio operates in the GMRS/FRS radio service area. 462.5625 to. 462.7250 MHz. The GMRS frequencies technically need an FCC license. Most people don't have a license.
GE Radio... | Answered on Mar 07, 2015
You cannot program the radio. Find a GE dealer. Business band, not consumer band and must be programmed with software and cables specific to this model of radio. MPI's were a good handheld. Model number is more helpful than a serial number.
GE Radio... | Answered on Jan 14, 2015
If the headset works normally, then check the headphone settings on that internet software, make sure that correct audio device is selected in the settings.
GE Radio... | Answered on Dec 09, 2013
Hi Howard,
Is there any noise or voice coming from the speaker before you try to transmit?
If so, you are trying to talk at the same time the channel is already in use, be it voice or someone holding down their PTT button without talking just to be a nuisance.
If this is correct, then nothing wrong with your radio, and nothing can be done about the button pusher blocking the channel.
Sorry if I have been of no help here, some things are beyond my scope.
Cheers,
Peter
GE Radio... | Answered on Mar 11, 2013
GE 2-way radios
8 Channel units, got that much, but you left out the most important bits, it's called information, we thrive on more info, the more the better, it saves us from having to guess what you require.
Cheers,
Peter
GE 30524ee3 3 Headset Corded/2 Cordless Dect 6.0 Answering Sys Lcd Display Used Logo
1 questions posted
Top GE Radio Communications Experts
Anthony Ward
Anthony Ward
ray gallant
Van Allen II
Van Allen II
Are you a GE Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • GE Radio Communications
Most Popular Question
need power adapter telephone base model
  • Radio Communications
