20 Most Recent Kenwood Kpg-35 V2.00 Programming Software Tk-480 Tk-481 Questions & Answers
The software program is KPG-35D and you need a cable that is KPG-36. I can't help you with the software because it is copyrighted by Kenwood. You should try looking in the Yahoo Groups section for a programming group or Kenwood group. Many have found the road to enlightenment doing so (if you get what I mean).
Kenwood Kpg-35... | Answered on Apr 18, 2015
http://goodwalkie.com/download.htm VERIFY THIS IF IS HELPFUL
Kenwood Kpg-35... | Answered on Mar 12, 2015
I HAVE KENWOOD TK480 AND I NEED SOFTWARE TO PROGRAME
Kenwood Kpg-35... | Answered on Jul 15, 2013
https://www.scribd.com/doc/3203857/TRC-70-Instruction-manual
Kenwood Radio... | Answered on Apr 14, 2020
First, clean all the connectors associated with this board. Over time they can get corrosion built up on them and they stop conducting. Use De-OXIT or Isopropyl alcohol to clean them. You may have to clean the deviation control on the board or replace C* and C10. I doubt if the microphone amplifier, Q1, is bad but if you can check the voltages around it, that might give you a clue. This problem shouldn't be too hard to fix as the rest of the radio is working. Good Luck!
a2y9jgk34igeaaaaaelftksuqmcc
Kenwood Radio... | Answered on Nov 13, 2019
Took me 6.5 seconds to find. https://www.manualslib.com/manual/908400/Kenwood-Tk-705.html Really, are you even trying?
Kenwood Radio... | Answered on Nov 12, 2019
You can connect it to the MIC input through a 10K resistor. That's the easy way. https://www.mods.dk/manual.php?brand=kenwood has a better method. Go to this website and look for the TR-9130 area and you'll find several files.
Kenwood Radio... | Answered on Nov 10, 2019
White is usually the audio wire. Black is ground and red PTT. The shield goes to the mic ground connection. The pinout is in your TS-440 manual.
It may be an out of market radio, meaning from another country. Most cannot be programmed to USA frequencies. It may be a frequency not allowed in that model. You did not list a frequency, you have a Uhf radio, it can only be programmed for Uhf, business band channels and a few others, like manufacturing or shared emergency channels. more information please.
Kenwood Radio... | Answered on Oct 04, 2019
That radio is past the end of life support and parts cannot be gotten. The older units had issues with chips in them that control the tuner and generate signals, the chips are custom made for Kenwood. You may be able to sell it on EBAY for parts.
Kenwood Radio... | Answered on Sep 27, 2019
See Service Manual PAge 11, if your problem not splve then remove R404 and see result, it will be OK.https://www.manualslib.com/download/582236/Kenwood-Tk-3202.html
Kenwood Radio... | Answered on Aug 07, 2019
Because your Radio is not power up so you have must change the EEPROM of your radio from Radio Service Shop, because your old EEPROM all data erased. Normally during update failure this not happen and Radio powerup, only programming of radio erase and LCD show no program and thid fault can be rectify when again updating process run, but your problem is not like that, your radio is not powerup, so you need to change EEPROM then your problem will be solve
Kenwood Radio... | Answered on Jul 11, 2019
https://www.voipon.co.uk/ippbx/pdfs/glocom_admin_manual.pdf From above link you can benefitted, because it is general full information for glocom user.
Kenwood Radio... | Answered on May 28, 2019
On you both device and make search with phone, when your phone sreach that device, it will show model numder, then you select your device and pair it.
https://www.manualslib.com/manual/1268780/Kenwood-Nx-210.html
Above link is for service manual for NX-210
Kenwood Radio... | Answered on May 10, 2019
Kenwood Kpg-35 V2.00 Programming Software Tk-480 Tk-481 Logo
3 questions posted
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Radio Communications
Most Popular Question
kenwood tk 480 need software program
  • Radio Communications
