20 Most Recent Icom Bp-209n W/ Mb-103 7.2v 1100 Mah Original Ic-v8 V82 U82 A6 A24 Questions & Answers
AT-180 ATU is not intended for IC-7300. Icom IC-7300 have a built-in tuner already. maybe you can use a special cable or interface to use the AT-180 on IC-7300.
Icom Radio... | Answered on Apr 21, 2020
Look at pages 16 to 20 in the user manual. This may give you some insight as to haw this may occur. Also, A google search for this radio brings up a lot of useful info. This is a complicated radio as is indicated by the 80 page user manual. It's not one that you can pick up and use right out of the box!
Icom Radio... | Answered on Nov 10, 2019
The link below should help you. Lots of info in the service manual. It's intended to let someone rebuild the radio from the ground up.
Try using an external speaker and see if you have the correct volume level. Radio speakers fail often, especially when used at high volume. The simple fix is to replace the speaker. It is seldom for the audio amplifier to fail this way. Usually they work or they don't.
Here's a link to the service manual - www.shercoares.org > doc_files > manuals > ica110_sm. This may help. Have you checked both fuses? They should both be about 10A. Use a meter to check them. A visible check may not show the fuses open.
I have an icom 91 and still haven't figured it out.
It is easier to use an app and computer and more intuitive.
Icom Radio... | Answered on Nov 03, 2019
http://www.icom.co.jp/world/support/download/manual/
Icom Radio... | Answered on Oct 10, 2019
You need to be a very good technical person with electronics to work on these. The issue is most likely a PLL board issue. You need to be able to troubleshoot to the component level. The service manual appears to be https://www.manualslib.com/manual/738448/Icom-Ic-706mkiig.html
Icom Radio... | Answered on Oct 09, 2019
it is available on web sight..download it.
Icom Radio... | Answered on May 21, 2019
Contact Icom directly to inquire.
Icom Radio... | Answered on May 20, 2019
Contact iCOM directly to inquire.
Icom Radio... | Answered on May 17, 2019
Sure sounds like a "low volts" reboot due to high current draw.
Are you measuring voltage at the radio itself, after any connector, fuse or circuit breaker? The voltage (at the set) should be slightly different between low and medium power tx. Use a good meter to confirm this. Is the power supply able to supply the current required at high tx power? Is a current limiter operating? A lead-acid battery in parallel with the PSU might be needed at high power.
At high power setting the radio will probably reset faster than a low power input voltage can be measured with a normal meter, so an oscilloscope might be needed to see the power input voltage as it happens (might be very brief).
Could RF be getting back into the power supply? Does it happen on both bands? Is the SWR good? Is the earth good? How long and how thick are the power wires? Is there any filter on the power supply wires (close to the radio)? If it's new there will be a warranty if it's a fault in the unit. Good luck :)
Icom Radio... | Answered on Apr 28, 2019
Que es el error? Aye un numero? Diga mas acerca de este problema.
Icom Radio... | Answered on Apr 08, 2019
Icom Bp-209n W/ Mb-103 7.2v 1100 Mah Original Ic-v8 V82 U82 A6 A24 Logo
1 questions posted
Top Icom Radio Communications Experts
Vincent G
Vincent G
Ngoro
ray gallant
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Icom Radio Communications
Most Popular Question
color come when batterry pack fully
  • Radio Communications
