20 Most Recent Connex Cx-366ce Night Runner 40ch Cb Radio, Very Loud Questions & Answers
Have a tunne pot dat has came out just the top part
try screwing it back in
10/3/2018 7:53:06 PM • Connex Cx-366ce... • Answered on Oct 03, 2018
Plugged in heard talk then nothing lights still worked but no power signal. help
probably sent enough power thru the reverse polarity diode to burd it but still have enough to keep lights on.
7/23/2014 5:58:56 PM • Connex Cx-366ce... • Answered on Jul 23, 2014
I have a cx-366ce cb cannot hear talking what is wrong
Is squelch turned too high that it is blocking too many signals? Otherwise, it could be a faulty cable on the mic as the PTT button disconnects the speaker on the CB and a broken wire can cause the speaker to be disconnected.
7/9/2014 11:13:54 AM • Connex Cx-366ce... • Answered on Jul 09, 2014
0answers
1 mile range on cb
Check cables and connectors. • check antenna SWR, A good SWR ranges from 1.2 to 1.5. • check power output.
8/2/2012 1:18:15 AM • Connex Cx-366ce... • Answered on Aug 02, 2012
Swr will not go under 2.5 even with antenna adjusted up and down
if your swr is higher on 1 then on 40 then your antenna is electrically short and you have to lenghten the antenna.If it is higher on 40 then on 1 then it is long and you have to shorten it. If you have to make it longer then you may have to add a quick disconnect or a coiled spring to make it longer. To make it shorter all you have to do is trim a 1/4 in at a time off the antenna whip but you must keep checking the match until it gets down below 1.5 .
10/3/2018 8:00:49 PM • Connex Radio... • Answered on Oct 03, 2018
My connex 3300hp radio randomly transmits and gets stuck without pressing mic button. It in sticks if you press mic button.
Have you tried keying it without the coax attached ? Take the mic apart and give it a squirt of electrical parts cleaner .Try using a different mic also.
10/3/2018 7:50:40 PM • Connex Radio... • Answered on Oct 03, 2018
Converting connex 4400 turbo to a cb
If you disable any part of the radio that does not pertain to CB then you could actually do damage to the radio. the best thing to do is leave it on the CB band and don't touch it.
10/3/2018 7:47:39 PM • Connex Radio... • Answered on Oct 03, 2018
When turn radio on channel indicator searches but will not stop search 3400 connex 3400
the radio is searching for a strong incoming signal and until it gets one it will search for one. Try turning off the scan button .
10/3/2018 7:44:35 PM • Connex Radio... • Answered on Oct 03, 2018
I stopped into a Radio shop and ask them for a power cord for my connex 4600 and he asked me what kind of truck I’m putting this radio in I told him a freightliner he said the connex 4600 Is the wrong radio for this this truck he said discharge don’t have a good ground I never heard that before
many trucks have a ground wire in the harness as the cabins are fibre glass or not grounded around the cabin mounts If the radio grounds out through the frame , then there would be no ground for the radio or the aerial wire to fit this particular may require such a wire in the harness for the radio which it probably doesn't have As you have been alerted to a problem, it would be advisable to talk with professional radio fitters who work on trucks to get the correct advice before starting on the job it could save a lot of frustration
11/23/2017 1:16:41 AM • Connex Radio... • Answered on Nov 23, 2017
Need a faceplate or faceplace sticker for a connex 4300x400wsm 10 meter cb radio. Any help at all would be greatly appreciated
Sorry we do not sell parts nor have the ability to locate them for you.
6/8/2017 6:29:00 PM • Connex Radio... • Answered on Jun 08, 2017
Connex Cx-366ce Night Runner 40ch Cb Radio, Very Loud Logo
6 questions posted
Top Connex Radio Communications Experts
Tony Raia
Damon Nesselrodt
Damon Nesselrodt
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Connex Radio Communications
Most Popular Question
tunne pot dat came out just top part
  • Radio Communications
